starting problem after cleaning out egr ports on intake
Old Sep 30, 2007 | 10:31 AM
eg:R's Avatar
Default starting problem after cleaning out egr ports on intake
how this starting problem occur. my car is a 94 honda accord ex.
first the car started to have a mis fire problem so i check out the egr ports and found out that 3 of the 4 holes were clog. i clean out the ports and now my car have a hard time starting. when i start my car i would really have to give it some gas for it to get it started. now my car have no more misfire but now have a starting problem. i have try a difference distributor, replace spark plugs and spark plug wires, replace fuel filter and still nothing. Anyone have this similar problem or can help me out what to check. thanks
Old Sep 30, 2007 | 10:44 AM
Duane_in_Japan's Avatar
Default Re: starting problem after cleaning out egr ports on intake (eg:R)
Clean the throttlebody next, check out the FAQ section please. Cracking the throttle open a little lets a little more air into the engine, a clean TB should do that by itself, did you plug everything back up (IACV), did you even disconnect anything????
Old Oct 1, 2007 | 05:22 PM
eg:R's Avatar
Default Re: starting problem after cleaning out egr ports on intake (Duane_in_Japan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Clean the throttlebody next, check out the FAQ section please. Cracking the throttle open a little lets a little more air into the engine, a clean TB should do that by itself, did you plug everything back up (IACV), did you even disconnect anything????</TD></TR></TABLE>
ok i will try cleaning the throttle body. the only thing that i unplug was some vacuum hoses and injectors. i was thinking could the dirt that i clean off the egr ports go to the egr and make the valve stick open???
Old Oct 1, 2007 | 09:21 PM
Secret Chimp's Avatar
The EGR ports are downstream of the throttle body, and the EGR valve is upstream of the EGR ports themselves. You didn't affect the throttle body or the EGR valve by cleaning the EGR ports, you just made issues further up the intake tract more apparent.
Old Oct 2, 2007 | 06:18 PM
eg:R's Avatar
what can i do to fix the problem?
Milano-ITR
Feb 13, 2010 08:39 AM
ekrise
Jul 21, 2009 07:07 PM
hoo my gosh
May 8, 2008 05:56 PM
thao0094
Jul 17, 2007 08:56 AM
IhateMy93BlackHatch
Nov 23, 2005 12:03 PM
