so nobody has a wiring configuration of a 99 si deck?
Old Jun 18, 2002 | 06:09 PM
lodown414's Avatar
Default so nobody has a wiring configuration of a 99 si deck?
need wiring configuration for an si deck to put into my prelude... and when do i type my anti theft code thing? does the display tell me to or do i just enter it?
Old Jun 19, 2002 | 08:26 AM
miahmouse's Avatar
Default Re: so nobody has a wiring configuration of a 99 si deck? (lodown414)
dont have the wiring info ........ but..... go get a wiring harness for a 99 civic (from somewhere with a lax return policy) write down the pinout described in the booklet and then return the harness. Unit should prompt for the code by displaying "COde" (I think you have ten tries before it locks itself, then you have to leave it on for an hour). Hope this helps.............
Old Jun 19, 2002 | 10:09 PM
philly-O's Avatar
Default Re: so nobody has a wiring configuration of a 99 si deck? (miahmouse)
go to best buy and buy a radio harness for a honda and a factory side harness (reverse harness) for a 99 on up honda and wire them togher so it plugs right into the dash with no mods or cut wires. both harnesses should cost a total of about $30 ($15 each)
Old Jun 20, 2002 | 04:04 PM
lodown414's Avatar
Default Re: so nobody has a wiring configuration of a 99 si deck? (peichie)
the wires are already cut on the dash side... i bought a sub harness but i think some wires are off... i need to know the configuratioin of the placment of the wires...
Redrover
Audio / Security / Video
16
Feb 17, 2011 02:12 PM
xMRDR3Wx
Jan 3, 2008 10:23 AM
CivicRider011
Dec 10, 2006 07:07 PM
rasta420
May 6, 2002 06:58 AM
