ctr and jr
WHATS UP HONDA HEADS I WAS WONDERING IF IT IS POSSIBLE TO A JR SUPERCHARGER ON A B16B ENGINE OR IF THE COMPRESSION ON THEM PISTONS IS TO HIGH TO PUT A SUPERCHARGER.ANY HELP IS GREAT THANK YOU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">Why supercharge it? It's aleady NA.</TD></TR></TABLE>
what?!? All honda's are NA from the factory, some people boost them. try the FI forum OP
https://honda-tech.com/zeroforum/16
GOD, YOU ARE AN ABSOLUTE WASTE OF SPACE!!!! STOP POSTING HERE YOU F*&%ING IDIOT!!!! JESUS TAPDANCING CHRIST!!!!
OP, you'll be fine mechanical-wise, the issue will be making it fit. You could contact Jacson Racing for more info or visit the FI forum like suggested above.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">Why supercharge it? It's aleady NA.</TD></TR></TABLE> This man :
would be more useful to honda tech then you.
Heck, he'd fit in the APC forum great!
he says YEAAA WHAT and THROW A LIP ON IT
Please go drink a gallon of a 50/50 mix of bleach and antifreeze.
it will work.
JRSCs actually work really well on higher compression motors on lower boost levels. because at higher boost levels, the blowers produce a lot of heat. most people run 10psi max without an intercooler. and ive seen setups up to 11.5:1 compression.
i was personally building an 11:1 compression 2.0L before i decided to go K series. i almost regret not finishing it.
you'll want to buy a kit for a type R. the head is the same bolt pattern so the JRSC manifold will fit. and the block height is actually the same so the rest of the brackets would work together.
Good Luck. it should be a pretty easy install and tune.
wow i know everyones already said it but.... just leave it'd be the best for all of us. make sure to never come back.
well thank you guys for all your inputs it will help me alot in my project.
OHHH! and to the guy that ask why supercharge? Cause is different and to beat you at the track with it
It'll fit fine, just use a 3.8" blower pulley for clearance around the brake master cylinder.
The dent in the strut tower for the alt pulley is closer to the crank pulley than it was before the blower swap. Don't let anyone tell you the dent is deeper.
Even though the CTR, ITR and GSR use the same block there is no "you have to use the ITR kit because you have a tall block."
The B16 kit or the ITR kit will fit fine. The only part that changes between the two kits is the blower pulley, which you will change to the 3.8".
You will have to bend the fuel line coming out of the firewall a little bit. Otherwise the horror stories about JRSC EF swaps are exaggerated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">Perfect sig material.</TD></TR></TABLE>
you forced him to change his name. I don't think he realized when we search his new name, all of his old threads still pop up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee »</TD></TR><TR><TD CLASS="quote">
No, he just got supremely owned in Kills. Notice how his location changed from NY to FL as well? The guy lives in MN. Stupid e-thugging troll that should be banned.
</TD></TR></TABLE>No, he just got supremely owned in Kills. Notice how his location changed from NY to FL as well? The guy lives in MN. Stupid e-thugging troll that should be banned.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loldohcvteclol »</TD></TR><TR><TD CLASS="quote">
Modified by loldohcvteclol at 10:04 AM 10/2/2007</TD></TR></TABLE>
God, you're dumb. We already have you quoted about 1782390512658916309 times.
Modified by loldohcvteclol at 10:05 AM 10/2/2007</TD></TR></TABLE>
thanks for the new sig material. you can try to hide your past, but we will never forget.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loldohcvteclol »</TD></TR><TR><TD CLASS="quote">Hey diary farmer. What you be doing chickenf8ckin'?</TD></TR></TABLE>
might be the case, but at least i know to ground the valve cover.
Who was that directed to? I'll assume me.
You obviously have the mental status of a 12-year-old in special ed classes. Don't get mad because you were destroyed in Kills you racist bastard.
That's right everybody. loldohcvteclol / 1988hondacrxsiR / abram_quito here doesn't like white folks and he ain't scurred to say it. I'll say it again, you should be banned with the quickness.
might be the case, but at least i know to ground the valve cover. </TD></TR></TABLE>
But those ground wires' locations aren't in his Alldata subscription, they're real hard to find!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loldohcvteclol »</TD></TR><TR><TD CLASS="quote">How was i kiiled in kills?</TD></TR></TABLE>
https://honda-tech.com/zerothread/2113728
https://honda-tech.com/zerothread/2113513
or is it this one?
or is it this one?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loldohcvteclol »</TD></TR><TR><TD CLASS="quote">HI
Don't believe it, now you're a strung-out crackhead?
You keep changing your s/n, your location, your age, your name, your sig, and now your pictures across two photobucket accounts? Are you a scam artist or just plain stupid?
Hahahahaha, he learned his lesson and made this PB album private.
</TD></TR></TABLE>Don't believe it, now you're a strung-out crackhead?
ban
