Crank position code 54 (need help with Cal ref)
My car breaks a lot!
ok i have a 97 civic ex with a 01 gsr swap, im throwing code 54
my problem is the civic harness has 2 wires and the gsr has 3 for this sensor, what do i do? is this the problem or is it something else?
The car runs fine, but I need to fix this in order to ref the swap.
thanks in advance for your help
Modified by teamvirus at 7:56 AM 9/30/2007
cut/solder/splice the two matching wires and tape the third up or find a b series crank position sensor connector and depin the two wires that match the harness and put them in the b bseries connector... so they're both 2 wire connectors... and tape the third wire to the harness... there is a post of this is the faq i think... ill try to find a link
heres a link to ff-squad.. it has more than enough information to help you with the crank sensor..
http://technet.ff-squad.com/
i got bored.. so i helped some more...
no pictures of the connector.. but its the information you need...
go-fast_integra
10
Oct 26, 2010 09:03 PM
panda_eh2
Nov 11, 2009 12:01 AM
crxfreak1117
Nov 28, 2007 05:56 AM
lilgreenman
Jun 17, 2003 04:40 PM
