99 EK With a GSR Cam Question
Old Sep 29, 2007 | 08:56 PM
JDMcivicSiEG6's Avatar
Default 99 EK With a GSR Cam Question
Whats going on everybody? Well I had a quick question, I have a 99 EK with a USDM Completely Stock Motor, I was just wondering what Cams would be the best on this???
Old Sep 29, 2007 | 09:05 PM
zerovandez's Avatar
Do you have a 99 civic with a GSR motor? or are you wanting to know if a GSR cam would fit in your stock 99 civic engine, which is NO it will not fit. Research a cam designed for your engine.
Old Sep 29, 2007 | 09:17 PM
Default Re: (zerovandez)
i have a 99 EK with a USDM Swap...I cant post anywhere else, since i only have a trial Version
Old Sep 29, 2007 | 09:21 PM
luvmihatch's Avatar
Default Re: (JDMcivicSiEG6)
nah i agree with the other guy that was kinda confusin.. but if u got a tock gsr u could put skunk2 cams in it.. but make sure u get stage ones bc they are safe on stock valve train.. or u can run type r cams.. but i say get skunks 2
Old Sep 29, 2007 | 09:34 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (luvmihatch)
If you're going to put cams in something, you might as well build the head and use massive ones - Stage 3+ - because otherwise you're really just wasting money. Stage 1 Skunk2 cams blow. Stage 2 are better, but they require valvetrain upgrades, at which point you'll probably want to go with better cams since you'll have the requisite support items.
Or. You could turbocharge your car and be done with it.
Old Sep 29, 2007 | 09:37 PM
luvmihatch's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">
Or. You could turbocharge your car and be done with it.</TD></TR></TABLE>
x2 sounds like the best idea.
Old Sep 29, 2007 | 09:39 PM
Thanx everybody I Aprriciate it, what about Cam Gears? What kind would be best?
Old Sep 29, 2007 | 09:42 PM
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMcivicSiEG6 &raquo;</TD></TR><TR><TD CLASS="quote">Thanx everybody I Aprriciate it, what about Cam Gears? What kind would be best?</TD></TR></TABLE>
Whatever's cheapest. You don't want to waste all this money without having a tuner handy because you won't be able to make crap for power with all your new toys running the stock fuel and ignition maps...
redyute
Jul 7, 2013 09:16 AM
xxjokoxx
Jan 20, 2009 06:02 PM
vw eater
May 15, 2008 09:11 PM
nbaonabc
Apr 11, 2004 12:21 PM
