Need help. 70mm Tb gets stuck
Old Sep 29, 2007 | 08:18 PM
Uniquerootz's Avatar
Default Need help. 70mm Tb gets stuck
Well my STR 70mm throttle body has been working fne up to recently. Not sure wheter it will be grime that wont let it close all the way or what. Opens all the way but when closing seems that theres still a tiny gap left open but enough to make my engine idle. Does anyone have any suggestions on what i can do???
Old Sep 29, 2007 | 08:22 PM
luvmihatch's Avatar
Default Re: Need help. 70mm Tb gets stuck (Uniquerootz)
i had the same problem
i took it off adn cleaned it out etc. but there was a tiny imperfection in the mold of the throttle body. and i grinded it out and got it repolished and it worked out... hope this helps but i would just take it off and clean it out...
Old Sep 29, 2007 | 08:33 PM
Default Re: Need help. 70mm Tb gets stuck (luvmihatch)
Thanks alot bro, was thinking about doing that. Im going to do that tomorrow. By the way, what was it that u cleaned it with???
Old Sep 29, 2007 | 08:37 PM
luvmihatch's Avatar
i jsut used carb cleaner.. but i also had acsess to a hot tank machine that was safe to use with the TB. but u should get away with carb / brake cleaner. keep me posted.. im do some resurch to see if there is any thing else out there
Old Sep 29, 2007 | 08:44 PM
Thanks aot bro, ill keep up this updated!!!
Old Sep 29, 2007 | 09:36 PM
ddd4114's Avatar
70mm? What do you have in there, a 351?
Old Sep 29, 2007 | 09:45 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Need help. 70mm Tb gets stuck (ddd4114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">70mm? What do you have in there, a 351?</TD></TR></TABLE>
Hopefully something with a lot of boost going into it. Otherwise, it's virtually wasted.
Old Sep 29, 2007 | 09:50 PM
ddd4114's Avatar
Default Re: Need help. 70mm Tb gets stuck (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Hopefully something with a lot of boost going into it. Otherwise, it's virtually wasted.</TD></TR></TABLE>
Even with boost, that's pretty big.
Singlecam4dr
Apr 9, 2010 01:42 PM
allricedout
Mar 13, 2007 08:47 PM
Fighterinsnatch
Jan 18, 2007 05:23 AM
smkngsr
May 9, 2005 07:06 AM
Al Bundy
Jun 26, 2003 09:56 PM
