Prelude Key Fob
Old Sep 29, 2007 | 05:41 PM
scott90's Avatar
Default Prelude Key Fob
I was wondering If I could program a 2000 prelude with a 2003 accord key fob like:
For the trunk button is it possible to program? I already know how to program car keys but can the trunk button be able to work with the prelude trunk? If it can't, how can I make it work?
thanks
Old Sep 30, 2007 | 10:20 AM
kadidle's Avatar
Default Re: Prelude Key Fob (scott90)
you would have to install a trunk release module and there is not panic or alarm system on a prelude
Old Sep 30, 2007 | 05:58 PM
slamdlude's Avatar
For starters the prelude and accord use different immobilizer systems and key blanks. On top of that the accord is a sidewinder key and the prelude uses the old hd106pt which is not high security. I'm also about 99 percent sure that if the platform is different for the immobilizer then it is probably different for the remote as well. Who knows though you could swap ecus, ignitions, wire in the transponder ring from the accord, install an actuator in the trunk for the trunk release, and hope it would program, but i wouldn't waste my time or money.
Old Oct 3, 2007 | 08:27 AM
CincinnatiBB6's Avatar
Kadidle: some 5th gens did come with alarms, it was a factory option. Mine came with the honda alarm. I'm guessing you will need to go to the stealership and see what they can do you for
Old Oct 3, 2007 | 02:47 PM
AznBlueBoy's Avatar
Default Re: (CincinnatiBB6)
my friend is using the newer TL key on his EP3.
im sure you can make it work but it just might not be worth the trouble.
hondaracin24
Dec 21, 2006 01:53 PM
mr.veilside accord
Oct 29, 2003 09:51 AM
kenshi23
Feb 24, 2002 01:26 AM
