how do i clean engine valves/springs? I want to inspect these parts, what do i look for?
Pop off the valve cover and look at them. it's not very hard at all. You probably don't need to clean them though.
Tell us what year and trim level you have so we can help you out
i have 97 honda accord. 4cyl. is the trim level found on label underneith hood of car(specifications). im not trying to sound ignorant, just am new to this topic. i already have valve cover removed. i found some oil deposits which i removed. the only reason i address this topic b/c my engine has an audible tap sound. thanks for guiding me. i will look into trim level.
Honda valve adjustments can be very touchy, a little loose and you get the sewing machine syndrome, a little tight and you loose all kinds of HP. Pick up a mechanics stethoscope at Sears and do some listening, you should be able to tell which valve is tapping the most.
