crx headlight question
Ok I was wondering if crx headlights were sealed beams or not. Cause one of my headlings has a hole in it so theres a bunch of dirt in it so I was wondering if I could take the headlight apart and clean out all the dirt.
But since there is a hole and it still works shouldnt that mean there not sealed beams?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">What year 88-89 not sealed and 90-91 are sealed beams but it's glass so be careful not to shatter them. </TD></TR></TABLE>
You are ******* full of ****.
None of them are sealed beam.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">
None of them are sealed beam.</TD></TR></TABLE>
he really smokes crack. that's the reason his responses get worse every day.
God, you are just absolutely retarded. Stop posting up BS info, you're going to hurt somebody one of these days.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 »</TD></TR><TR><TD CLASS="quote">To oh yeah crx make a write up of this with pictures. I WOOOULD like to see if you can clean them internally??</TD></TR></TABLE>
You can you dumbass. But I figured you'd know that already, since you have an answer for everything. Just shut your freaking trap already.
You are an absolute retard. You can't figure out how to clean them on your own?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loldohcvteclol »</TD></TR><TR><TD CLASS="quote">Are you sure does are the original ones?</TD></TR></TABLE>
Yes, I am sure. Completely certain, as a matter of fact. Are your headlights the original ones?
I used a shop-vac with a piece of skinny vacuum hose taped to the vacuum hose to vacuum water out of it before. And the broken pieces of bulb that were caused by water splashing onto the bulb.
Perhaps the OP could look in a convenient on-line parts catalog (I know hondaautomotiveparts dot-com has one; I'm sure other places do as well) for the exploded diagrams that show the bulbs being separate from the housing. That would be a relatively easy way to verify that the HL are in fact not sealed beams.
--DD
--DD
Pooby88
Jan 10, 2006 07:34 AM
sm00thk0zz
Sep 13, 2004 11:06 AM
No More Civic
May 23, 2002 07:23 PM
