d15b2 with a d16a6 head, timing issues?
Old Sep 29, 2007 | 12:07 PM
290allen's Avatar
Default d15b2 with a d16a6 head, timing issues?
Does anyone know if i can use the factory cam gear and still time my motor corectly, tried to search this but didnt come up with the answer i needed. Thanks In Advance
Old Sep 29, 2007 | 05:17 PM
peanut butter's Avatar
Default Re: d15b2 with a d16a6 head, timing issues? (290allen)
This is exactly what I'm running and basically the only way to get it timed correctly is with a cam gear. With the stock cam gear the timing is always off by like half a tooth or so.
Old Sep 29, 2007 | 05:22 PM
The_Undertaker's Avatar
75.168.105.221
You can also advance or retard the timing by the distributor.
Old Sep 29, 2007 | 05:24 PM
Default Re: (1988hondacrxsiR1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988hondacrxsiR1 &raquo;</TD></TR><TR><TD CLASS="quote">You can also advance or retard the timing by the distributor.</TD></TR></TABLE>
Yes you can, which I did, but it still can't be timed up to factory spec, its always retarded with the dizzy all the way advanced. You might be able to get away with cutting notches on the distributor legs though.
Old Sep 29, 2007 | 05:27 PM
75.168.105.221
You can TRY to align TDC by oil pump arrow mark to close as possible and cams TDC and have it close to spec.
Old Sep 29, 2007 | 05:29 PM
COrrect, I'm referring to ignition timing though.
Old Sep 29, 2007 | 06:24 PM
turbostd's Avatar
Default Re: (peanut butter)
use a d16y cam gear to correct cam timing and the set ignition timing to stock.
Old Jun 8, 2009 | 08:00 PM
290allen's Avatar
i will be trying a d16y cam gear tomorrow. will let yall know how it goes.
Old Jun 12, 2009 | 11:41 AM
290allen's Avatar
The d16y7 cam gear i tried is working. i can set my timing to stock finally.
from what i have gathered any d16y* cam gear will work. hope this helps someone.
,Philip
Old Mar 22, 2010 | 02:46 AM
steeltoe's Avatar
extra info on this:
https://honda-tech.com/forums/showth...6a6+head+d15b2
Old Mar 23, 2012 | 10:33 AM
jlob85's Avatar
Hate to bump a thread so old, but I figure it's better than starting a new one.
I'm about to do a mpfi swap on my dx, but I'm also throwing on a d16a6 head at the same time. I got everything I need for the swap, including the si distributor, but which cam gear should I use? I think that's a different question than was asked here because I assume this guy was staying with dpfi.
Thanks in advance for the help.
Old Mar 23, 2012 | 12:58 PM
greenchad's Avatar
d16y cam gear if 89-91 A6.
88 A6 is indexed the same as the d15b1/2
Old Mar 23, 2012 | 07:34 PM
jlob85's Avatar
What about using the cam gear from the db2 head?
XVNVX
Aug 7, 2017 10:31 AM
arbys2k
11
Jun 28, 2009 04:46 AM
all-mtr-teg
17
Aug 26, 2007 07:45 PM
dat_flip
Sep 15, 2004 12:11 AM
Alias
Jan 28, 2003 06:56 PM
