YCP Vitara 75.5mm pistons - need help on piston/cylinder clearances!
Old Sep 29, 2007 | 09:54 AM
Redz_EX's Avatar
Default YCP Vitara 75.5mm pistons - need help on piston/cylinder clearances!
Running a Greddy turbo kit on a 00 D16Y8 engine, will run 6 to 10 psi boost. I'm looking for piston to cylinder wall clearance specs for this application. Anybody running these with a similar setup and had good luck the a certain piston to cylinder wall clearance?
I've seen many threads out there that mention piston slap on the standard size pistons, so I'm going 20 over to eliminate this.
Thanks in advance for your input!
Redz_EX
May 14, 2008 10:21 PM
DRGnzo
Mar 18, 2008 11:29 PM
Nisif
Mar 6, 2005 03:36 PM
seako_916
May 19, 2004 08:52 PM
