lsvtec turbod
prob vtec YS1 with or without LSD is your best bet. Im running a old LS in my build I cant see spending 600 for YS1 when I can get LS for couple hundred dollars specialy if you just out screwing around..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef9boosted »</TD></TR><TR><TD CLASS="quote">need help what tranny to run an is it a good idea to continue doing this to my ef9? i only use it to have fun with my krew?
</TD></TR></TABLE> ....
just walk.
You didn't give us 1/20th of the info we needed to help you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90lsvcrxva »</TD></TR><TR><TD CLASS="quote">prob vtec YS1 with or without LSD is your best bet. Im running a old LS in my build I cant see spending 600 for YS1 when I can get LS for couple hundred dollars specialy if you just out screwing around..</TD></TR></TABLE> You might be legally retarded, check into getting a grant for that the goverment loves spending my tax dollars on people like you, sadly not improving them to a enuich.
</TD></TR></TABLE> ....just walk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 »</TD></TR><TR><TD CLASS="quote">Hey Max....Im not kewl enough for a KREW...are YOU?
******* **** mang.</TD></TR></TABLE> No, I tried to but they said, you can't hang unless you are a junior at the local HS and your dad is a lawyer.
I'm just not from a gangsta back round
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liverider20020 »</TD></TR><TR><TD CLASS="quote">id say definitely a Ls if your gonig boost bro</TD></TR></TABLE>
Look newb, did you even read his post? He wants to know some info on trannys.
Here is the tranny the OP needs!
Modified by SIred91 at 10:19 PM 9/30/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liverider20020 »</TD></TR><TR><TD CLASS="quote">id say definitely a Ls if your gonig boost bro</TD></TR></TABLE> Wow, that's some shitty advice thanks for posting
SiHater
Oct 26, 2006 01:01 PM
