b16a type R bottom end!
Old Sep 28, 2007 | 08:11 PM
domsb16's Avatar
Default b16a type R bottom end!
what would be the best way to build a b16a type R bottom end ? since the bore and stroke on a b16a and a type R are the same, can itr pistons be installed with no issues? or is a stroker kit the best route? thanx
Old Sep 28, 2007 | 08:29 PM
roastbeefrichie's Avatar
Default Re: b16a type R bottom end! (domsb16)
this may help you: http://www.c-speedracing.com/h...c.php
Old Sep 28, 2007 | 09:48 PM
strawberry's Avatar
correct me if i'm wrong but i always thought
type R really= gsr bottom end B16 head p&p, itr pistons and valve train
Old Sep 29, 2007 | 08:19 AM
domsb16's Avatar
Default Re: (strawberry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strawberry &raquo;</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong but i always thought
well in cc's yes but wont this bring up my compression. I'm already running type R valves, springs, retainers and camshafts in my pr3 head, its also p&p too.
Old Sep 29, 2007 | 08:31 AM
SIred91's Avatar
Rainman
Default Re: (domsb16)
The bore and stroke is NOT the same between a B16 and a B18c5
Old Sep 29, 2007 | 08:38 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: (SIred91)
uh neato a b16a type R .....
b16b is a de stroked b18c5, not a de stroked gsr and not a b18c de stroked to a b16a.
My word.
Old Sep 29, 2007 | 02:35 PM
domsb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">The bore and stroke is NOT the same between a B16 and a B18c5 </TD></TR></TABLE>
correct my bad... i was reading the chart wrong... the b16a bore x stroke is 81.0x77.4 and the b18c5 is 81.0x87.2.. so since the bore is the same can I install the 96 spec itr pistons which have a compression ratio of 11.1 or I'm I better off buying a stroker kit to bring up my compression and displacement? thanx to everyone... this bottom end has been bug'n me cause I'm so undecided of what to do with it..
Old Sep 29, 2007 | 05:04 PM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by domsb16 &raquo;</TD></TR><TR><TD CLASS="quote">what would be the best way to build a b16a type R bottom end ? since the bore and stroke on a b16a and a type R are the same, can itr pistons be installed with no issues? or is a stroker kit the best route? thanx</TD></TR></TABLE>
the stroke from a b16a and type R are the same? that's news to me.
Old Sep 29, 2007 | 05:06 PM
correct my bad... i was reading the chart wrong... the b16a bore x stroke is 81.0x77.4 and the b18c5 is 81.0x87.2.. so since the bore is the same can I install the 96 spec itr pistons which have a compression ratio of 11.1 or I'm I better off buying a stroker kit to bring up my compression and displacement? thanx to everyone... this bottom end has been bug'n me cause I'm so undecided of what to do with it.. </TD></TR></TABLE>
okay, now that i have read this....
yes, you can install ITR pistons in your B16 bottom end. it will bump the compression up. your displacement will still be 1.6L though.
Old Sep 29, 2007 | 05:17 PM
highflyinhonda's Avatar
The bore is the sam dia. from the factory on all b series motors except the b20. However they are all stroked differently and the blocks do differ. If im not mistaken the deck height is defferent between a b16a and a b18c5. this goes along with having a different stroke. Also crank and rod journal sizes are all the same dia. on the b series cranks from the factory. If you were to take b18c5 crank, rods, and pistons and put them in a b16a the pistons would protrude above the deck more than they would in a b18c5 block. This will probably cause piston to valve clearance issuses. With that being said, im pretty sure you can put b18c5 internals in a gsr block without any issues. Plus you have the main girdle for strength in higher rpms like the type r block.
Old Sep 29, 2007 | 05:56 PM
domsb16's Avatar
Default Re: (highflyinhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highflyinhonda &raquo;</TD></TR><TR><TD CLASS="quote">The bore is the sam dia. from the factory on all b series motors except the b20. However they are all stroked differently and the blocks do differ. If im not mistaken the deck height is defferent between a b16a and a b18c5. this goes along with having a different stroke. Also crank and rod journal sizes are all the same dia. on the b series cranks from the factory. If you were to take b18c5 crank, rods, and pistons and put them in a b16a the pistons would protrude above the deck more than they would in a b18c5 block. This will probably cause piston to valve clearance issuses. With that being said, im pretty sure you can put b18c5 internals in a gsr block without any issues. Plus you have the main girdle for strength in higher rpms like the type r block.</TD></TR></TABLE>
thanx alot for the helpfull info.. I'm thinking about just swapping out my pr3 pistons for a set of p30 to pick up my compression ratio for now, until I can get my hands on a gsr block... again thanx to everyone for the info
Old Sep 29, 2007 | 11:05 PM
Thats a pretty good upgrade but you should try to get some pct (b16b) pistons instead. I had those in my hatch for 2 years before it got stolen. You will feel a lot more from those than you will the p30 IMO.
Old Sep 30, 2007 | 11:19 AM
domsb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highflyinhonda &raquo;</TD></TR><TR><TD CLASS="quote">Thats a pretty good upgrade but you should try to get some pct (b16b) pistons instead. I had those in my hatch for 2 years before it got stolen. You will feel a lot more from those than you will the p30 IMO.</TD></TR></TABLE>
do you know where I may be able to prchase these pct's at? by the way thanx alot for all your knowledge...
Old Sep 30, 2007 | 11:20 AM
do you know where I may be able to prchase these pct's at? by the way thanx alot for all your knowledge... </TD></TR></TABLE>
try inlinefour.com or hmotorsonline.com i think i recall seeing pct pistons at one or both of those websites.
http://inlinefour.com/jdmhonoempis.html
http://hmotorsonline.com/shop/...10002
Old Sep 30, 2007 | 11:32 AM
I bought mine from hmotorsonline. They are pretty cheap and oem honda quality.
Old Sep 30, 2007 | 03:39 PM
domsb16's Avatar
thanx ya'll i was looking on jhpusa and there were 100$ more than hmotorsportsonline... u guy's rock!!!!
Old Sep 30, 2007 | 10:24 PM
EF_FEVER's Avatar
I'm just waiting for some p30 piston to get my poor man r running. My b16a is still running. I can't wait!!!!!!!!!!!!!
Rik Tarrh
Nov 23, 2017 08:50 PM
blade0314
21
Apr 18, 2008 01:29 AM
S1_DJai
Mar 25, 2006 07:01 PM
Mar_DC2
May 9, 2003 11:38 AM
