3200 rev limiter
Just did an ls swap into my 91 civic hb and it works fine but out of nowhere i get a rev limiter at around 3200 and it smells really rich. If you gun the gas quickly it boggs really bad. I reset the ecu and then it works for a little bit but i'm not sure if it's the ecu, dizzy, a sensor, not sure,
It is throwing a code 4 and a code 9.
Please any ideas would be great.
Modified by northemt88 at 9:25 PM 9/28/2007
The search button is your friend: https://honda-tech.com/zerothread/1710584
yeah i checked those sensosors and i'm having trouble tryiong to figure out why a tps or a crank position sensor would do this so intermitently
i changed the dizzy it ran fine but out off now were it did it again.so i turned off the car and good as new.maybe the wires my friend switched on the dizzy are wrong
SOHC Gord
Nov 19, 2004 04:47 AM
ejprimo
Apr 16, 2003 05:12 PM
