91 Accord wont start and NO click.
The battery tests fine main relay is new and verified working. Turn the key and usual stuff comes on radio and such, go to crank it and nothing. Not even clicking. Ignition Switch? Shift Lock Release? ECU? Pretty much verified everything else I could.
... may be your neutral safety switch ..put shifter on neutral and try ... if nothing your best bet is to check power with the help of wiring diagram first at stater then ignition switch then neutral swuich ... hope it helps....
thegrobe
Sep 3, 2009 09:30 AM
BlazeTeck2000
Dec 8, 2005 03:39 PM
notoriousB
Jan 11, 2005 03:28 PM
