dumb question.. can a car build boost if i jack it up and drive through gears?
Old Sep 28, 2007 | 04:34 PM
97grnrs's Avatar
Default dumb question.. can a car build boost if i jack it up and drive through gears?
it sounds stupid so dont ask but if i put my car on a lift and have the wheels off the ground and go through gears carefully will the car build any boost or does it need to see a load from the ground ??
Old Sep 28, 2007 | 04:52 PM
mitsuman's Avatar
Default Re: dumb question.. can a car build boost if i jack it up and drive through gears? (97grnrs)
It will build some boost, just like revving it will, but exactly how much? Not a lot. The engine has to be under load.
Old Sep 28, 2007 | 07:03 PM
Bailhatch's Avatar
Default Re: dumb question.. can a car build boost if i jack it up and drive through gears? (mitsuman)
ride the brakes
Old Sep 29, 2007 | 05:38 AM
97grnrs's Avatar
Default Re: dumb question.. can a car build boost if i jack it up and drive through gears? (Bailhatch)
i never thought of riding the brakes but in theory that would work i guess haha ...
Old Sep 29, 2007 | 06:25 AM
sc4dr's Avatar
What in the world are you trying to do?
Old Sep 29, 2007 | 09:12 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
Default Re: dumb question.. can a car build boost if i jack it up and drive through gears? (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">What in the world are you trying to do?</TD></TR></TABLE>
He's trying to drive through the back wall of his garage.
Bailhatch's Avatar
build boost!
just hook up the jackstand version of the G-tech and you got yourself a dyno!
Old Sep 29, 2007 | 09:49 AM
ek_chris's Avatar
sure ya can.. lol
Old Sep 29, 2007 | 10:00 AM
SovXietday's Avatar
Default Re: (ek_chris)
****, most turbo Honda's don't need to be up on jackstands to spin the tires and go nowhere.
Old Sep 29, 2007 | 10:15 AM
97grnrs's Avatar
Default Re: dumb question.. can a car build boost if i jack it up and drive through gears? (rota92)
ha , im trying to watch my AF while tuning without a dyno... i know sounds dumb but i got a shop to do it at i only need to build a few psi to test what i need to.. and if something goes wrong ill have it in the shop where i can just fix it..
Old Sep 29, 2007 | 12:48 PM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">ha , im trying to watch my AF while tuning without a dyno... i know sounds dumb but i got a shop to do it at i only need to build a few psi to test what i need to.. and if something goes wrong ill have it in the shop where i can just fix it.. </TD></TR></TABLE>
Not the same because you have no load .
Old Sep 29, 2007 | 01:26 PM
97grnrs's Avatar
Default Re: dumb question.. can a car build boost if i jack it up and drive through gears? (MidShipCivic)
wouldnt riding the brakes simulate a load?
Old Sep 29, 2007 | 01:46 PM
Yeah it does but you shouldn't do it for tuning just drive the car start off rich and lean it out like every tuner does.
Old Sep 29, 2007 | 03:35 PM
97grnrs's Avatar
Default Re: (MidShipCivic)
ya i got a good tune but i had a reason to suspect my zdyne ecu was not functioning properly and if i blow the motor again i rather it be in my shop.. but ill see .. im hoping for the best
Old Sep 30, 2007 | 10:44 AM
rorik's Avatar
I don't get it. The only thing I can figure is you have a wideband in the shop but not connected in the car?
Old Sep 30, 2007 | 10:49 AM
confucioussae's Avatar
Default Re: (rorik)
Ask your mom, dad, sister, grandma, whatever, to help watch the meter while you drive.
Old Sep 30, 2007 | 01:13 PM
crowder13's Avatar
or have someone else drive it and u tune
Old Sep 30, 2007 | 01:16 PM
Schister66's Avatar
Man U FTW
the title of this thread just screams "BAD IDEA INSIDE"
Old Sep 30, 2007 | 01:27 PM
95teilhatch's Avatar
Default Re: (Schister66)
lol thats what i have been thinking for 2 or 3 days now
Old Sep 30, 2007 | 01:56 PM
97grnrs's Avatar
Default Re: (95teilhatch)
might be a bad idea but ive done worse so i aint worried about it
Old Sep 30, 2007 | 01:58 PM
Schister66's Avatar
Man U FTW
Default Re: (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">might be a bad idea but ive done worse so i aint worried about it </TD></TR></TABLE>
that's not very reassuring
xtremvw
Jun 4, 2008 09:11 AM
cehcivic15
Feb 23, 2008 11:43 AM
iBrandon
Sep 21, 2007 06:14 PM
Turbo_TONY
Jun 23, 2006 11:21 AM
g3teg97
Jan 11, 2006 04:18 PM
