2004 Acura TL Turbo info (automatic)
I have a friend who has a 2004 acura TL V6 and we were looking into the comptech supercharger, but wanted to see what was out there along the lines of a turbo kit. The kit DOES NOT have to be all put together.
SO is anyone running a turbo TL (of the newest generation) on either the auto, or 6speed tranny. and if so, how much did you spend, and what did you have to do. And yes i did search with no succsess.
hey man you will have a hard time finding anything comptech cause they went out of business unless you go used i havent seen a turbo kit on any 04-08 tl i have seen it on a 03 cl-s but you will be looking at around 2500-4000
awesome thanks for the info. You can still get the supercharger from some online retailers that still havnt sold out. How are the auto trannies on these cars? I used to have an 00' accord coupe ex v6 auto and the trannies on those are ****. would the trannies on these cars be able to hold the extra power the turbo would produce?
I've seen 2 turbo 06 TL's 6 speed and 1 auto at HIN. do not turbo an automatic, you loose money and time, as with manual you get your moneys worth. the auto slips at 8k and boost is laggy as expletive well it still pulls
Exactly how high does the auto v6 rev on its own (in standard D without "shifiting" it yourself)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fabe85 »</TD></TR><TR><TD CLASS="quote">do not turbo an automatic, you loose money and time, as with manual you get your moneys worth. </TD></TR></TABLE>
Can you explain this?^^
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skingfreak »</TD></TR><TR><TD CLASS="quote">Exactly how high does the auto v6 rev on its own (in standard D without "shifiting" it yourself)
Can you explain this?^^</TD></TR></TABLE>
yo just relax ur nerves, i've seen auto on 10 psi all day pushes 297 hp. and i've seen same setup on 10 psi stock tl type s push 321 on 10 psi
type-s's start out with more power to begin with, so thats probably the added numbers your seeing, plus gearing is a factor im sure.
BTW my nerves are fine, i was simply asking for an explanation
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by micha »</TD></TR><TR><TD CLASS="quote">The type S also has a 3.5 liter as opposed to a 3.2 liter motor. </TD></TR></TABLE>
Good point
Good point
zangiefisgod
Dec 27, 2009 05:32 AM
pi282
Feb 22, 2006 01:54 PM
