"new" turbo is perfect accept.....
Old Sep 28, 2007 | 01:18 PM
ds0440's Avatar
Default "new" turbo is perfect accept.....
hey i finally got my turbo. it is a 2006 wrx turbo TD04L. it is in pretty good shape no shaft play at all but, the internal waste gate is open. i can move the actuator arm, but it just seems to stop early can it be adjusted? it looks like i just need to loosen that nut a little. but what do you guys think? here are a few more pics.
Old Sep 28, 2007 | 01:20 PM
Boostdc4's Avatar
Default Re: "new" turbo is perfect accept..... (ds0440)
just losen the lock nut then pop off the clip and turn it back till its closed
Old Sep 28, 2007 | 01:27 PM
ds0440's Avatar
Default Re: "new" turbo is perfect accept..... (Boostdc4)
thanks
Old Sep 28, 2007 | 01:32 PM
Jim Truett's Avatar
Straighten out the actuator arm. It looks like it was dropped and bent in shipment.
Old Sep 28, 2007 | 01:34 PM
EASY101's Avatar
* B A N N E D *
that actuator arm looks a little bent... but adjusting it may fix the prob.
Old Sep 28, 2007 | 03:08 PM
97grnrs's Avatar
if u have to u can cut a tad bit off like an eighth of an inch and re weld it back together so it stay shut.. just make it so its snug and the circle part wont spin around when its closed .. too tight and you will boost more than u might want to.
Old Sep 28, 2007 | 03:09 PM
thewrai6th's Avatar
Default Re: "new" turbo is perfect accept..... (EASY101)
The actuator arm looks like it was in an accident, or was bent straight. Putting the stock bends back will also tighten up the WG arm, along with the nut adjustment.
Old Sep 28, 2007 | 03:48 PM
EASY101's Avatar
* B A N N E D *
Default Re: "new" turbo is perfect accept..... (Mr Wonderfull)
actually isnt there an adapter plate that covers the hole and allows you to eliminate the internal wastegate all together?
Old Sep 28, 2007 | 04:27 PM
Calvinator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Wonderfull &raquo;</TD></TR><TR><TD CLASS="quote">weld that ****** shut and get an ext WG</TD></TR></TABLE>
Old Sep 28, 2007 | 04:58 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EASY101 &raquo;</TD></TR><TR><TD CLASS="quote">actually isnt there an adapter plate that covers the hole and allows you to eliminate the internal wastegate all together?</TD></TR></TABLE>
Adapter plate = welder.
Old Sep 28, 2007 | 05:09 PM
EASY101's Avatar
* B A N N E D *
Default Re: "new" turbo is perfect accept..... (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
Adapter plate = welder. </TD></TR></TABLE>
That obviously would work but wouldnt an adapter plate be a cleaner way to do it? I just dont know if adapter plates like the one I'm thinking of are available for all turbos, because I've only seen them for the T3's.
Old Sep 28, 2007 | 08:05 PM
Hondaruss's Avatar
pop to C clip off the arm loosen the jam not screw the tab in to where the gate is completely shut vola..done. And also on the FP red turbos you can twist the WG arm and adjust them s well!
Old Sep 28, 2007 | 08:45 PM
japan4racing's Avatar
quis84
Sep 30, 2008 08:50 PM
JDMtegg19
Jan 21, 2008 02:06 PM
fastvtecCL
Jun 17, 2007 10:44 AM
da_konig
Apr 24, 2004 06:12 AM
Ri5e
May 7, 2002 05:23 PM
