F22 cam gear - # of teeth?
lots of help in here....maybe I should have asked a less technical question.
how many teeth are on a B series flywheel? how many teeth are on a D series Timing belt?
now let me ask this....why do you want to know? there is probably an easier question that will give you the same answer...
[Modified by 01GSR, 12:03 PM 6/19/2002]
why ask why? apparently no one here knows, or cares to say.
anyway, I've figured it out, thanks niedejb for the suggestion. the cam gear has 40 teeth as I suspected and the center bore is 20mm.
well my guess is something like you're trying to see if a F series cam gear will work on a D series...
i mean, there has to be a reason your asking, which would make the question easier, cause the one you asked is just pointless
