Crank - No spark...
Old Sep 28, 2007 | 12:08 AM
spinnergee's Avatar
Default Crank - No spark...
Hi there all - I've got a 1991 Hatchback that really deserves to come back to life, but I cannot figure out how to get spark...
I've replaced the Cap & Rotor - and the coil... I have power to the black & yellow wire and power to the white/blue wire, but no spark.
I found a grey box, with a 16 pin conector with a white & blue wire amongst many others tucked up underneath the passenger dash, and my assumption was that it may be a defunct car alarm - inside the box, the circuit board is labelled "STANLEY S-386IF" and on the outside, it only has "MF06" The harness that goes to this box, joins in right where the ECU wiring meets the firewall, and it looks stock, so I didn't pull it apart to look at it yet. I did remove the odd gray box and it's sitting here next to my computer.
Afterwards I did remove a Solenoid from the main fuse box under the drivers dash, but no luck.
Can aybody point me in any of the right directions ? Any help would be great, as the haynes manual I have doesn't even have the proper schematic for a 91...
Thanks,
Ken
Old Aug 18, 2008 | 09:13 AM
scottmog's Avatar
Default Re: Crank - No spark... (spinnergee)
how old is the fuelpump and main relay?
if u dont know then do this.
1. turn the key to 2nd position.
2. do u hear the click (main relay) and the humming sound (fuel pump)?
3. if u dont hear one of those then look at number 2 to give u the answer of what to fix
titi_vtec
Nov 5, 2010 07:37 AM
nemeii
Oct 13, 2008 02:29 PM
spinnergee
Audio / Security / Video
Sep 25, 2007 03:59 PM
TouringAccord
Mar 8, 2004 03:05 AM
