D16 knock sensor probs obd1 and 2...
well here is the start of my troubles... i bought the car used witht he swap already done.... i have a d16z6 block with a b16y8 head... the motor is running off of the obd1 ecu with the jumper harness, when i hook up the obd2 ecu the CEL comes on and when read says KNOCK SENSOR and MANUFACTURER CONTROLED IGNITION, i know what the ignition prob is... but the knock sensor is my issue, i know out there in the hundreds of civic drivers and tuners there is someone that can tell me how to add a knock sensor to this obd1 d16z6 block, or at least i hope... thanks guys for any suggestion about how to get this thing running better
running on the obd1 ecu it has a slight miss to it... im guessing where the obd1 and 2 ignition systems are diff, so i try the obd2 ecu but it looks for a knock sensor... for some odd reason if none of the d's have knock sensors (according to 89efdusty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imaginespyders »</TD></TR><TR><TD CLASS="quote">running on the obd1 ecu it has a slight miss to it... im guessing where the obd1 and 2 ignition systems are diff, so i try the obd2 ecu but it looks for a knock sensor... for some odd reason if none of the d's have knock sensors (according to 89efdusty)</TD></TR></TABLE> please see https://honda-tech.com/zerothread?id=234047 maybe I am reading something wrong. If you have a z6/a6 block you should not have a knock, head "y8" does not matter concerning the knock.
I'm super confused with this post now
Running OBd2 on a non knock sensor equipped block
Just stick with OBD1 "best Diagnostic system to tune
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imaginespyders »</TD></TR><TR><TD CLASS="quote">yep its screwin me up too, the z6 obd1 block with the y8 obd2 head... wats the point?? </TD></TR></TABLE> Your post confuse me...is this a question or statement with a "?". z6 block = no knock so run obd1 on a p28 /thread
Labarum
21
Aug 7, 2011 04:28 AM
Si Shane
Aug 2, 2005 05:41 AM
