Question! Can I put an H22 Head on an
Old Jun 18, 2002 | 12:16 PM
H23A1LUDE's Avatar
Default Question! Can I put an H22 Head on an
Hey Luders....I have a couple questions for you. 95 Si Lude H23A4 108,000..could I put an h22 head on an h23 engine? Theres an h22 head for $700 and I also wanted to know if h22 rods and pistons would fit into an h23....I was told I should build up my engine rather than swap....
Old Jun 18, 2002 | 12:20 PM
Prelude Vtec 23's Avatar
Default Re: Question! Can I put an H22 Head on an (H23A1LUDE)
You can swap the h22 head on the h23 block. Their's other things that need to be done too. You might want to try a search first, their have been several topics on this before.
Old Jun 18, 2002 | 12:21 PM
2point6's Avatar
check out http://www.collectiveracing.net There is a list of parts located there on this build-up under general performance. There have been mixed reviews on doing this build up.
Old Jun 18, 2002 | 01:13 PM
JG Luder's Avatar
Default Re: Question! Can I put an H22 Head on an (2point6)
The H22A parts don't fit the H23A I don't believe. But the head will bolt on with some modifications. $700 is a touch high, you probably could find one on http://www.thepartstrader.com, or http://www.ebay.com for around $500-$600.
Good luck.
Old Jun 18, 2002 | 01:17 PM
bgod's Avatar
Default Re: Question! Can I put an H22 Head on an (JG Luder)
$700 is a good price if that is including a complete head.
but then you'll need to source the intake manifold and tb. fuel rail/injectors, etc.
imho, this conversion is a total waste of money. many mixed reviews as 2point6 has pointed out above.
an h22a jdm longblock can be had for $1500 or less. i'd go that route.
if you can't do any of the motor work yourself, a shop will charge you a good $1000-$1500 in labor alone. parts not included.
Old Jun 18, 2002 | 01:40 PM
H22Si's Avatar
Default Re: Question! Can I put an H22 Head on an (bgod)
https://honda-tech.com/zerothread?id=185771
Old Jun 18, 2002 | 03:33 PM
H23A1LUDE's Avatar
Default Re: Question! Can I put an H22 Head on an (H22Si)
So basically you guys are telling me to get a new engine?........Or should I keep my 108,000 mile H23A4 and get forged pistons, rods and rings? Header, intake, exhaust.....New engine or Build up?.....what would I search for on EBAY.....h23a head?....I can't find anything.....thanks for the advice guys n girls
[Modified by H23A1LUDE, 12:37 AM 6/19/2002]
Old Jun 18, 2002 | 10:24 PM
PrecisionH23a's Avatar
dont do the hybrid, read the forum linked above. you would be better going FULL h22a
Old Jun 19, 2002 | 06:22 AM
H22Si's Avatar
Default Re: Question! Can I put an H22 Head on an (GudeH23a)
Full H22A
Brandonf22
Feb 22, 2008 06:32 PM
djbrandonr
Jan 29, 2007 03:08 PM
NightMare
Oct 25, 2006 09:36 PM
yellow4dr
Dec 19, 2004 06:28 AM
92hondalude
Sep 21, 2004 02:44 PM
