EF Headligths?
Do they make glass JDM headlights for the ef. I hate when the plastic one turn yellow I clean and clean mine but they still look a little bit yellow and if they do were can i get some thank...
he has JDM lights, which are plastic.
get some 2000 grit wet sand paper, hit the head lights till they have an even texture, then hit it with Mcquires Scratch-X and an orbital polisher. 3-5" should do it. use a wool buffing pad
use heavy pressure with liberal amounts of compund. they will turn out like new. i do it all day every day at work
Actually most of the time, the yellow-ness is from the actual bulb insde the headlight. You need to take the lens off and clean the inside. Don't waste your time on cleaning outside if you do it over and over. You need to get inside the housing to clean...don't know how the plastic JDM lights hold up when baking, but I know you can bake the glass ones in the oven for a few minutes and the lens comes off pretty easily.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ilovemyef9 »</TD></TR><TR><TD CLASS="quote">Do they make glass JDM headlights for the ef. I hate when the plastic one turn yellow I clean and clean mine but they still look a little bit yellow and if they do were can i get some thank... </TD></TR></TABLE>
JDM Glass headlights? No. EDM LHD glass headlights for the EE9/EF9 front? Yes. Some of the headlights also came with the motorized tilt feature
As for the yellowing, if the car is a DD even if you polish them; the yellowing will come back after a few months-a year. Once the UV coating is sanded/worn off over time, there's really nothing stopping oxidation/sun damage from occurring. Personally I wouldn't worry too much about that though. Just polish them really thoroughly once a year and wax every other week or every car wash
. As for the yellowing, if the car is a DD even if you polish them; the yellowing will come back after a few months-a year. Once the UV coating is sanded/worn off over time, there's really nothing stopping oxidation/sun damage from occurring. Personally I wouldn't worry too much about that though. Just polish them really thoroughly once a year and wax every other week or every car wash
^^ correct you can get a edm set which are made for LHD so the beam pattern is better and they take regular h4's not the stupid h4h's . some do come with the motorized adjustment option
EGKREW
14
Jun 25, 2008 03:57 PM
tigueremalo
11
Feb 9, 2007 02:48 PM
