BBS Evo wheels on ITR
Old Sep 27, 2007 | 08:06 AM
done's Avatar
Default BBS Evo wheels on ITR
Has anyone tried to fit BBS Evo wheels on an ITR?
Old Sep 27, 2007 | 08:31 AM
YellowKahuna's Avatar
Default Re: BBS Evo wheels on ITR (done)
https://honda-tech.com/zerothread?id=960219&page=22
Look at user name Locs car
Old Sep 27, 2007 | 08:36 AM
GO-FIGHT-KILL's Avatar
Those are Infiniti/FC3S wheels, and I love them.
I think he's talking about stock Evo wheels though.
Old Sep 27, 2007 | 08:45 AM
done's Avatar
Default Re: (GO-FIGHT-KILL)
stock evo wheels are 17x8 +38 .. So im going to try to fit them.
maybe with 215 or 225 size tires.
Old Sep 27, 2007 | 08:46 AM
17x8 with a +38 offset? What kind of suspension do you have?
Old Sep 27, 2007 | 09:03 AM
done's Avatar
Tein RAs
Old Sep 27, 2007 | 09:09 AM
jomama's Avatar
those are awfully wide wheels at 8 inches...
JjuuN R's Avatar
Default Re: (done)
That's going to be a tight tight fit.
Old Sep 27, 2007 | 09:51 AM
done's Avatar
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">those are awfully wide wheels at 8 inches... </TD></TR></TABLE>
Well my train of thought is. 15x8 volks at +43 fit pretty snug. Im thinking itll still fit if use a 215 size tire.
Old Sep 27, 2007 | 09:52 AM
Sturmmann's Avatar
Default Re: (JjuuN R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by done &raquo;</TD></TR><TR><TD CLASS="quote">stock evo wheels are 17x8 +38 .. So im going to try to fit them.
maybe with 215 or 225 size tires. </TD></TR></TABLE>
It will work. Though running 205/40 will be much more comfortable...rubbing wise. If your chassis/suspension allows it...205/45. This 17x8 +38 is a flush setup...at least 5mm past fenders.
215 or 225 is wide...unless you are not that low.
Old Sep 27, 2007 | 10:21 AM
Default Re: BBS Evo wheels on ITR (YellowKahuna)
Whoops
LOCC's car still looks good to look at though
Old Sep 27, 2007 | 10:22 AM
Locc's Avatar
thanks hah not to thread jack 15x7 19/50/15 ftw what size and stuff
Old May 4, 2009 | 10:34 AM
done's Avatar
anyone tried it yet... im pulling evo wheels of soon and going to try.
Old May 4, 2009 | 10:46 AM
red_crx's Avatar
I know the evo8 wheels fit...You just have to use the right style of lug nut (off the same evo is fine). A little camber would help also. I have a feeling the new wheels might be along the same lines.
Old May 4, 2009 | 02:57 PM
jzak1's Avatar
Evo 8 wheels fit perfect, it just depends on tire sizes from then. good luck
Old May 4, 2009 | 05:51 PM
legomytego's Avatar
i can only assume they fit ok ive seen a picture of a tl with the mr bbs wheels and ive seen tl wheels on a integra so i guess in theory it should work out ive made a thread about this myself if you search my name and i was told as long as you not to low it should work out. i am trying to find a local to swap with.
Old May 4, 2009 | 06:50 PM
RockinaRHard's Avatar
Unless they were free or crazy cheap I would not bother.
Plenty of choices for 'fitting' wheels.
Old May 5, 2009 | 09:45 AM
done's Avatar
Well I have an evo se that im putting wheels on.
Suzukablue
Nov 22, 2012 08:33 AM
ej_b16a
Nov 28, 2007 04:43 PM
Rahxephon
Honda Civic (2006 - 2015)
Apr 26, 2007 11:19 PM
typeass
Aug 5, 2004 10:58 AM
00siBuilder
Mar 29, 2004 03:41 AM
