just picked up new rex need some help
ok so i picked up a 88 crx si with a d16y8 out of a 99 civic
picked it up for 800
now i need some assistance first thing i noticed is the speedo cable is busted
and vtec doesnt work CEL is on the ecu is flashing code 16 which is fuel injectors
i cant find anything wrong with them though
next it looks like the harness is homemade its all kinds of hacked so what harness/jumper etc... do i need to use
it also has a obd0 jdm b16 ecu (that is what i was told at least) so yeah let me know whats up need to get this thing runnin right so i can get my turbo on it but this swap owns me for free
The harness is homeade...???
Sounds like it was ghetto rigged, thats probably what is causing you to get a CEL...a wiring issue. If it were me, and you had the time and money, get a whole new wiring harness and redo it all, the RIGHT wiring harness for the car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rleonekc »</TD></TR><TR><TD CLASS="quote">The harness is homeade...???
Sounds like it was ghetto rigged, thats probably what is causing you to get a CEL...a wiring issue. If it were me, and you had the time and money, get a whole new wiring harness and redo it all, the RIGHT wiring harness for the car</TD></TR></TABLE>
Absolutely. You can never trust somebody else's hack-job. That code 16 is coming from crappy wiring.
I agree with rleonekc and wiZCo you need to go over that harness and make sure it is correct. It sounds like you will have to fix someone else mistakes before you start doing what you want. No big deal just sucks sometimes.
i bleieve it has y8 injectors
it runs fine lol other than no vtec runs like a top has a slight valve tap and the injectors tick
but other than that it runs great
it has been run open header so im gonna have to do a valve job anyway
and what harness and jumper combo do i need being its an obd2 motor?? and what other hsit am i gonna have to make sure matches the harness
basically where the expletive do i start
i hate wiring probles even with car audio i get frustrated
Downgrade the motor to OBD1 and convert your car to the same. Looks like you're going to have a hell of a lot of work on your hands. Search for "OBD1 conversion" in the FAQ, it'll be pretty much the same process.
you know you would think that but it has been runnin like this no problems for a year
i just want VTEC!!! cause im plannin on boosting it
SOHC Warrior
Jun 8, 2012 06:08 PM
C_R_X_V_T_E_C
Mar 6, 2007 03:45 PM
infantry
Feb 10, 2004 09:54 PM
