Best a/f ratio for ITR.
Old Jun 18, 2002 | 11:44 AM
pinota's Avatar
Default Best a/f ratio for ITR.
Hi,
Running Endyn 82.mm, 11.3 CR pistons, i/e/h, FPR, what a/f ratio whould be good to run safe.
iŽll be running a Greddy a/f meter, how acurate is it ?
Thanks,
Pinota
Old Jun 18, 2002 | 01:01 PM
AK94GSR's Avatar
Default Re: Best a/f ratio for ITR. (pinota)
Yeah I was looking into the same greddy gauge. Does anyone know how accurate it is????
Old Jun 18, 2002 | 01:04 PM
Big Phat R's Avatar
A little on the rich side of stoichiometric
Old Jun 18, 2002 | 01:21 PM
Black R's Avatar
25 Year Member
.....not very. Still uses your stock sensor.
Try wideband for something accurate. The DIY one is about the same price and much more dead-on for accuracy.
Old Jun 18, 2002 | 01:29 PM
SilverS's Avatar
Default Re: Best a/f ratio for ITR. (Black R)
doenst it come with its own o2 sensor?
its in the picture above.....
JoshRambo's Avatar
around 13.1:1
Old Jun 18, 2002 | 03:03 PM
Big Phat R's Avatar
It uses the sensor pictured above (the one with the yellow wire). I think it is a standard 02 sensor though.
PB - who has one of these but hasn't installed it yet because he can't find a place to put it
Old Jun 18, 2002 | 05:29 PM
sneakychaos's Avatar
Default Re: Best a/f ratio for ITR. (Phat Bastard)
Believe it or not they are pretty damn accurate. Ran mine in parallel to a WideBand O2 @ the dyno... wasn't off by more then .2 in any one spot. Make sure you set it properly on the brain otherwise it'll bounce all over the place.
Yes, its a standard O2 sensor.. and yes, it comes with its own; doesnt use the stock O2's. (Although, it CAN.)
Old Jun 18, 2002 | 05:30 PM
Default Re: Best a/f ratio for ITR. (trooth)
On a side note, I REALLY wish you could change the colors of them. I like the silver gauge, but I wanted black to keep my interior as much the same (black) as possible... too bad it lights up green. The silver is actually a very close match to the stock color of the R's interior. (And it does match 2G DSM's, too.)
Old Jun 18, 2002 | 06:04 PM
Peter K's Avatar
New User
Does anybody have any info on where one can purchase that?
Old Jun 18, 2002 | 06:20 PM
typer694's Avatar
New User
Default Re: Best a/f ratio for ITR. (Peter K)
Dan at Godspeed sells them.
Old Jun 18, 2002 | 06:58 PM
EK4 hatchback's Avatar
How do you set it properly?? I have one installed and i could only read it at full throttle. Thanks.
Old Jun 18, 2002 | 07:37 PM
Default Re: Best a/f ratio for ITR. (EK4 hatchback)
RTFM. In english, read the f*cking manual.
Anywho, there is a button on the back of the brain, in which you push and it will read 9:1, 11:1, 13:1 and 15:1... those are the settings to tell the sensor what type of exhaust it will be received to properly diagnose it. I'm not sure whats what, I believe 9:1 is high pressure (boost+awd+hot) 11:1 is high pressure (boost/awd cars and sensor is farther back) and 13:1 and 15:1 are low pressure, close and further respectively. Again, RTFM and it will tell all.
BTW - if anybody is in need of one, let me know. I can get them fairly cheap. ($250 shipped) for white/black... silver ones are on backorder.
Old Jun 18, 2002 | 07:38 PM
The second "button" type thing on the right... (the one all the way to the right.) Is where you push in to set it. Do this with the car OFF, and the ignition ON.
Old Jun 19, 2002 | 09:10 AM
I only have the Japanese manual since i bought it in Japan last year. Thanks for your advise.
[Modified by EK4 hatchback, 10:14 AM 6/19/2002]
Old Jun 19, 2002 | 10:57 AM
vtec2nr's Avatar
<U>Steady State Conditions</U>
Idle 14.7:1
full load= 13.2:1
<U>Transient Conditions</U>
Acceleration= no richer than 12.7:1
Deceleration= no leaner than 17.1:1
Starting and warmup= between 11.0:1 and 10.3:1
WOT(open loop) is the only place where an A/F meter, without a wide-band O2 sensor, is accurate enough to tune by. In closed loop, the O2 cross-counts are too high to get an accurate reading.
[Modified by vtec2nr, 2:59 PM 6/19/2002]
Old Jun 19, 2002 | 03:57 PM
pinota's Avatar
Default Re: Best a/f ratio for ITR. (vtec2nr)
Thanks a lot.
Pinota
Old Jun 19, 2002 | 04:52 PM
primoEF's Avatar
How do you do that?
Old Jun 19, 2002 | 07:19 PM
thanks
BLB
Feb 6, 2009 01:36 PM
Tad
Mar 7, 2005 10:53 PM
speedymon
Mar 2, 2004 02:33 PM
NXSpoon
May 20, 2003 06:15 PM
JM Performance
Nov 22, 2001 10:57 AM
