brakes noise
ok i searched guys seriously. my noise for my brakes arent squeeky noises that seems like i need new brakes or just rust. the noise is wen i press on the pedal i hear like a loud thump coming from the brakes. neone got this problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imroadk1ll »</TD></TR><TR><TD CLASS="quote">ok i searched guys seriously. my noise for my brakes arent squeeky noises that seems like i need new brakes or just rust. the noise is wen i press on the pedal i hear like a loud thump coming from the brakes. neone got this problem. </TD></TR></TABLE>
Does it continuessly do it?... slow down as your car slows down?... Does the car shake with said "thumping"?
If you answered yes to all three questions... You may have something on your rotor at best... scrape it off and your on your way. Possibly cracked rotor...
... more info needed...
Yeah, I agree with thinknology. Could also be a warped rotor. Does your car shake when you hit the brake? Do you have ABS? Your ABS system may be errored, in which case you might be able to fix by starting the car with the ABS fuses out.
Does this sound come at all when you accelerate or turn hard?
Can you tell if it is from the front or back? If so are the brakes' disk or drum in that area?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lucid_Nightmare »</TD></TR><TR><TD CLASS="quote">Yeah, I agree with thinknology. Could also be a warped rotor. Does your car shake when you hit the brake? Do you have ABS? Your ABS system may be errored, in which case you might be able to fix by starting the car with the ABS fuses out.
Can you tell if it is from the front or back? If so are the brakes' disk or drum in that area?</TD></TR></TABLE>
I like this noob
I like this noob
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thinknology »</TD></TR><TR><TD CLASS="quote">
I like this noob
lol rofl and wat else hahaha.
well the noise only happens after i start the car then i press on the brakes, only during the begining then i press on the breaks again then no noise. doesnt happen wen im accelerating or turning. i have ABS of course its an 04.
I like this noob
</TD></TR></TABLE>lol rofl and wat else hahaha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imroadk1ll »</TD></TR><TR><TD CLASS="quote">just audible</TD></TR></TABLE>
That's odd... usually with brakes you can feel it...
It only happens when you press the brakes though right? and just right at first when you depress it... does it happen everytime you depress the brake pedal or does it only do it one time after you turn your car on and then it won't do it anymore?
It only happens when you press the brakes though right? and just right at first when you depress it... does it happen everytime you depress the brake pedal or does it only do it one time after you turn your car on and then it won't do it anymore?</TD></TR></TABLE>
only does it once after i turn the car on after that no more
