94 accord balance shaft
hi i was wondering what would get damaged if te rear balance shaft was not lined up properly when installing a balance shaft belt on a 94 honda accord 2.2 engine. thanks for your input
The engine will be out of balance and you may feel it, follow the manual and a 1/4 inch extension, I believe that is what most folks use to find the notch in the shaft.
You are going to have to follow directions on re-timing the balance shaft, also it is common to over tighten the balance belt and its tensioner bracket rattles, it only needs its own spring tension, lots of folks like to make it tighter by hand and then lock down the tensioner.
Obd 1uan
Nov 2, 2006 05:47 PM
professorman
Apr 14, 2003 02:10 PM
