Code 41
Old Sep 28, 2007 | 09:15 AM
bobmac's Avatar
Default Code 41
Code 41 on a 1992 Accord EX (Primary HOsS (No. 1) Heater System).
Is the solution just to replace the O2 sensor at the base on the exhaust header ?
How can I measure whether the new one is working properly ?
Mech also says EGR ports are plugged causing uneven distribution (misfire under load)
Will a Seaform treatment fix this, or do I have to 'un-plug' the intake and scrape the carbon out of it ?
Old Sep 28, 2007 | 12:23 PM
JimBlake's Avatar
Default Re: Code 41 (bobmac)
Unplug the O2 sensor & find the 2 same-color (black??) wires attached to the sensor. Measure resistance between them - should be 10 to 40 ohms. If not, you need a new sensor.
If that resistance is OK, then the problem may be the car's wiring. In that case a new sensor won't help.
I think there's a thread around here somewhere about the EGR ports, but I've never had to do that so ???
Old Sep 29, 2007 | 04:38 AM
Duane_in_Japan's Avatar
Default Re: Code 41 (JimBlake)
Jim, I forgot, which fuse protects the heater, I forgot, cig lighter???????
Old Sep 29, 2007 | 05:10 PM
dueceman's Avatar
Default Re: Code 41 (Duane_in_Japan)
the egr port cleaning threads are in the FAQ ..covers most models..
Old Oct 1, 2007 | 04:32 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Duane_in_Japan &raquo;</TD></TR><TR><TD CLASS="quote">Jim, I forgot, which fuse protects the heater, I forgot, cig lighter???????</TD></TR></TABLE>Probably not the same for all years/models. IIRC, on my '95 Integra it was the same fuse that supplied power for the ECU.
daluv
11
Jan 3, 2021 07:21 PM
sick93sol
Aug 5, 2007 03:50 AM
SONIC BOOM
Jun 23, 2006 06:40 AM
vtec25
Mar 14, 2006 02:39 AM
BeavisB16
Apr 29, 2005 03:57 PM
