Benefits of using a GSR crank in a B20 block?
I will picking up a b20z block from a friend. he also has a gsr crank and girdle along with forged gsr rods. what are the benfits of running this kind of setup
plan to get a b16 head to go on top of this
yea it will still be good and put out good numbers but ur gonna loose 2mm's of stroke and some torque thats about it. i say go for it.
correct me if i'm wrong, torque makes power..hences keep the b20 crank..or find a lightned ls crank. Losing 2mm of stroke is a good bit..it will hurt both your whp and wtq..why would you want to switch to a smaller crank anyway.. makes no sense unless your in a bind and need a new crank?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R »</TD></TR><TR><TD CLASS="quote">correct me if i'm wrong, torque makes power..hences keep the b20 crank..or find a lightned ls crank. Losing 2mm of stroke is a good bit..it will hurt both your whp and wtq..why would you want to switch to a smaller crank anyway.. makes no sense unless your in a bind and need a new crank?</TD></TR></TABLE>
not necessarily EKJavi used a ITR crank in his build found here https://honda-tech.com/zerothread?id=2071065
and made 260.5 hp and 166.8 ft/lb of tq
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotaeg6 »</TD></TR><TR><TD CLASS="quote">
and made 260.5 hp and 166.8 ft/lb of tq </TD></TR></TABLE>
yeah.. but the question now is would he have made more HP with the LS crank.
imo, yes.
imo, yes.
hybridpatient95
20
Jan 4, 2005 05:07 PM
