Civic Type R pulley...what belt??
Old Sep 26, 2007 | 11:09 PM
swapped95's Avatar
Default Civic Type R pulley...what belt??
What belt do i use with this pulley? its smaller than the stock crank pully on my lsv build...
thanks in advance
Old Sep 26, 2007 | 11:49 PM
swapped95's Avatar
bumpity
Old Sep 27, 2007 | 09:12 AM
swapped95's Avatar
ttt
Old Sep 27, 2007 | 01:17 PM
ToeJam's Avatar
Default Re: Civic Type R pulley...what belt?? (swapped95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swapped95 &raquo;</TD></TR><TR><TD CLASS="quote">What belt do i use with this pulley? its smaller than the stock crank pully on my lsv build...
thanks in advance </TD></TR></TABLE>
The timing belt is determined by what water pump you’re using. The ctr crank pulley is smaller because at higher revs it will prevent your alternator from being overdriven. I have an itr pulley on my build and I had to use itr belts for all my accessories. Hope this helps. Good luck with your build.
Old Sep 27, 2007 | 04:44 PM
2ltrtodd's Avatar
* B A N N E D *
uhhh dude your timing belt doesnt go on the crank pully it goes on the oil pump.
use whatever belt is mean for your car, the alt is adjustable.
Old Sep 27, 2007 | 05:19 PM
ToeJam's Avatar
Default Re: (2ltrtodd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ltrtodd &raquo;</TD></TR><TR><TD CLASS="quote">uhhh dude your timing belt doesnt go on the crank pully it goes on the oil pump.
use whatever belt is mean for your car, the alt is adjustable.</TD></TR></TABLE>
He's right. the alt belt can be adjusted but it can only be adjusted so far. If the size of the ctr pulley is anything like the itr pulley, the LS belt will not work. It's too long even when the alt is pulled all the way out. This is coming from first hand experience, take it or not it’s up to you. good luck
Old Sep 27, 2007 | 05:51 PM
4GE4YA's Avatar
I have a ctr pulley on my b16a swap in a 90 model ef hatch. I used a napa # 25-040292. It works perfectly. I had to roll it on to the crank just a little bit. But it fits great.
Old Sep 27, 2007 | 07:01 PM
swapped95's Avatar
thanks guys i picked one up at autozone...i also had to roll it on but it fits great...and yes its the PULLEY not a crank gear...
Old Sep 27, 2007 | 07:03 PM
swapped95's Avatar
and the oem didnt work with the tensioner all the way out the belt was still too big...i used autozone part #290k4...whatever belt that is...
swapped95
Sep 27, 2007 10:39 AM
vtec.dc2
Sep 11, 2007 05:58 PM
1994CivicGS-R
May 2, 2006 01:52 PM
DocSean
Jan 16, 2006 09:20 PM
integra*RS*
Oct 9, 2003 07:13 PM
