k20a2 swap into base
WHAT IF YOU HAVE ALL THESE THINGS:
- Motor
- Hydraulic Tranny
- ECU (PRB)
- Axles with Half Shaft
- Shift Cables and Shift Box
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
- Comes With All Sensors Needed
BUT YOUR CAR IS A BASE AUTO WOULD IT BE POSSIBLE TO SWAP THE K20A2 INTO THE BASE AUTO?
- Motor
- Hydraulic Tranny
- ECU (PRB)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Coils
- Engine Harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1llmatic »</TD></TR><TR><TD CLASS="quote">yes its possible.
immobilizer might be the only issue.</TD></TR></TABLE>
why is that?
why is that?
