where to find the 3.5 mini fd for b18c
Old Sep 26, 2007 | 04:50 PM
austrian type-R's Avatar
Default where to find the 3.5 mini fd for b18c
I know it is out there, but I could not find it. I am searching for the 3.5 final drive the mini guys are using.
Old Sep 26, 2007 | 05:27 PM
Bradstard's Avatar
Default Re: where to find the 3.5 mini fd for b18c (austrian type-R)
http://www.minimania.com/web/I...l.cfm
Old Sep 26, 2007 | 05:29 PM
Hooch'n's Avatar
Default Re: where to find the 3.5 mini fd for b18c (Bradstard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bradstard &raquo;</TD></TR><TR><TD CLASS="quote">http://www.minimania.com/web/I...l.cfm
Old Sep 26, 2007 | 05:49 PM
GO-FIGHT-KILL's Avatar
I guess because the cars are so light, the engine doesn't need that tight of gearing?
Old Sep 26, 2007 | 05:57 PM
JjuuN R's Avatar
Default Re: (GO-FIGHT-KILL)
Be the perfect FD for you Christian, time to step it up to about 260kmph...
Old Sep 26, 2007 | 06:03 PM
RTW DC2R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">I guess because the cars are so light, the engine doesn't need that tight of gearing?</TD></TR></TABLE>
his car (like mine) has the power to pull through that longer gearing. gear ratios of the ITR trans stay the same (unless he has swapped gears or is using a non ITR trans of course), but each gear is longer which means blowing by supercars on the straights without falling out of VTAK!! or running out of gear FTW
holy **** that part is expensive. christian have you used the MFactory 4.05FD yet? I had it on my car for awhile and it was awesome. you could run the 4.05 with a slightly taller tire...
Old Sep 26, 2007 | 06:11 PM
D's Avatar
D
Tire diameter is off by about 3".
The 3.5 ratio is retarded however, i have no idea why the other mini guys spend so much for this FD. 4.0-4.1 should be about right.
Old Sep 26, 2007 | 11:12 PM
Default Re: (D)
I need stronger gears and it seems DOG boxes only come with ultra short close gears and only Quaife make a 5speed box, Liberty and Ericks only a 4speed Dog box. I thougth on the 3.5 fd, ITR 1st and 2nd gear and ATS 3,4,5.
hehe, the 3.5fd and the longest 5th gear of 0.714 with 605mm tirediameter (I have) and 9000rpm are more than 400kmh!!!!! LOOOOOL ...somebody should try that.
Old Sep 26, 2007 | 11:24 PM
tartje's Avatar
Default Re: (austrian type-R)
jesus that 3.47 is expensive
although, i guess it depends how many they sell. can't see it exactly being a volume product
Old Sep 27, 2007 | 07:11 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by austrian type-R &raquo;</TD></TR><TR><TD CLASS="quote">I need stronger gears and it seems DOG boxes only come with ultra short close gears and only Quaife make a 5speed box, Liberty and Ericks only a 4speed Dog box. I thougth on the 3.5 fd, ITR 1st and 2nd gear and ATS 3,4,5.
hehe, the 3.5fd and the longest 5th gear of 0.714 with 605mm tirediameter (I have) and 9000rpm are more than 400kmh!!!!! LOOOOOL ...somebody should try that.</TD></TR></TABLE>
Dog boxes are badass. A buddy of mine has one in his DSM.
I'm Trying
Feb 19, 2007 01:46 PM
Luke
Honda Motorcycles
27
Jan 30, 2005 02:21 PM
86si
Oct 4, 2004 06:48 PM
C-Zero
Welding / Fabrication
Aug 22, 2004 08:14 AM
spock_rocker
Jan 3, 2004 05:34 PM
