trani knocking!
Old Sep 26, 2007 | 04:29 PM
k0rupt_ed's Avatar
Default trani knocking!
I started to notice it yesterday, and today its gotten louder. I'm a bit worried.
Lets say I'm in neutral the clutch isn't engaged, Im just sitting there, I have a knocking sound, its bugging the **** out of me, as soon as I engage the clutch it goes silent, wtf can it be? flywheel? I realy don't think its the engine, I listened under the hood it sounds like trani
help me out guys 1.5l d15
Old Sep 26, 2007 | 05:46 PM
akunamatta's Avatar
* B A N N E D *
how loud is it?.. usually i can hear something spinning inside and it quiets down when i engage the clutch but thats it.
Old Sep 26, 2007 | 06:44 PM
92hatchboi's Avatar
Default Re: trani knocking! (k0rupt_ed)
could be yoyur throw out bearing
Old Sep 26, 2007 | 06:49 PM
k0rupt_ed's Avatar
its a knocking sound not a whining like the throw out
Old Sep 26, 2007 | 06:53 PM
drtysohc's Avatar
if it is making noise with clutch out, it is the tranny (or in some weird situations it could be the release bearing if the clutch isnt fully disengaging.)
if it is making noise when the clutch is pushed in, or when you're letting it out it is either pilot bearing or release bearing.
Old Sep 26, 2007 | 06:59 PM
k0rupt_ed's Avatar
when the clutch is disengaged
Old Sep 26, 2007 | 08:10 PM
Ek4_honder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k0rupt_ed &raquo;</TD></TR><TR><TD CLASS="quote">I started to notice it yesterday, and today its gotten louder. I'm a bit worried.
help me out guys 1.5l d15</TD></TR></TABLE>
its the pilot bearings or i think its the throwout bearings..mines does the same ****, but imma swap an ex tranny soon...
Old Sep 27, 2007 | 10:36 AM
k0rupt_ed's Avatar
went to the local import shop today, its the throwout bearing.. pheww
also said my valves were tapping just a bit, prob from gunk and build up
120k on the engine
anyone have any comments on using seafoam?
Old Sep 27, 2007 | 12:31 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (k0rupt_ed)
Seafoam works very well if used correctly. Also make sure to change your oil after you use it.
Old Sep 27, 2007 | 12:36 PM
EL Vap133's Avatar
I say it is the Main Input Shaft bearing, about a $20 part from Honda. The labor is what costs.
Old Nov 12, 2007 | 09:42 PM
jezuzgirl's Avatar
Default Re: (wiZCo)
Did you have your car repaired after finding out it was the throwout bearing? If so how much did it cost? My car is doing the same thing.... I was affraid it was the motor too, but can't believe that it would be. Also, if you know, how much to get valves adjusted, mine are also clacking...
Glad I found your post. This has been driving me nuts...
Old Nov 13, 2007 | 02:58 AM
cjk95delsolsi's Avatar
I dont mean to disappoint you, but if you said that you have a knocking noise in neutral and press in the clutch and it goes away it is your input shaft bearing.
Here is another way to check, take your car for a ride going less than 5mph in 1st gear and listen for the knocking. Either way if you press in the clutch and the noise goes away it is the input shaft bearing. I have had it go out on me with 2 trannys. But dont worry, it is fairly easy to replace. Besides dropping your tranny.
I have a complete write-up for you including photos from Bauley Civic. It is a very good write-up and its what I used to do the job. Here it is https://honda-tech.com/zerothread?id=596873 If you have any question you can pm me and I will do what I can to help. I have dropped my tranny several time and pulled it apart twice. Good Luck!
Old Nov 13, 2007 | 07:05 AM
k0rupt_ed's Avatar
Yeh I know.. I realy don't want to waste my time on this d15 trani but I have no other options.. seems I'm gonna have to bite the bullet before it bites me...
I read your writeup a few weeks ago you did a great job with detail.
Thanks for the reply
AlaskaREX
May 30, 2013 06:53 PM
Solstic
Jun 13, 2012 11:34 AM
illi Adik
Honda S2000
May 11, 2009 07:24 PM
Beezle
Oct 2, 2004 10:25 AM
nY's FiNeSt
12
Oct 22, 2003 04:06 PM
