Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 civic tail light/ gauge/ fuse problem
Old Sep 26, 2007 | 03:48 PM
Dillon91Teg's Avatar
Default 01 civic tail light/ gauge/ fuse problem
hey everybody. i installed 04-05 tails on my 01 coupe a while ago. however lately, the fuse for my tail lights (not brake lights) and dash lights keeps blowing. i replace it, but it just goes randomly. i checked my wiring job on the tail lights and everything looks okay, so what could the problem be? any help would be greatly appreciated. thank you
Old Sep 26, 2007 | 05:09 PM
JDM_7th Civic's Avatar
didnt know the 04-05 lights could fit on 01-03's i like the sound of that
Old Sep 26, 2007 | 05:24 PM
1llmatic's Avatar
New User
Default Re: (JDM_7th Civic)
did you install oem 04-05 taillights or aftermarket?
Old Sep 26, 2007 | 08:13 PM
toyomatt84's Avatar
Sanji
Did you extend any wires during the procedure? Because that's typically what you have to do.
Old Sep 27, 2007 | 04:22 PM
honda917's Avatar
Default Re: 01 civic tail light/ gauge/ fuse problem (Dillon91Teg)
blowing fuses means u are drawing to many amps, or u have a short in your wiring somewhere, most likely u have a short to ground in the wiring if it does not happen right as u put the fuse in the that means that you only are shorting the wire over bumps or something, check all the wiring see if u have any bare wire showing that might be the cause
Old Oct 2, 2007 | 09:29 PM
i think i'm going to install my original tail lights again, and hopefully that will stop the issue. that way i can point out whatever problem alot more easily. thank you all for all the help.
LogsTeggy
Mar 29, 2015 04:13 PM
lilshady6796
Nov 12, 2008 06:33 PM
benji7288
Dec 29, 2007 08:33 PM
slo_hatch
Dec 14, 2007 09:52 AM
