what plug is this on ls block?
i got a question..im putting together my ls-vtec motor and im setting everything up to run my catch can and on the back of the block i have 3 plugs...one is the oil pressure sensor then it has another sensor which minei believe is broke i just see 2 pins sticking out and then theres another sensor that has a green plug..
what sensor is this? is it safe to unscrew that off and use the honda plug for a catch can?
im running obd1 del sol
heres a pic i found online that shows exactly which 2 plugs im talking about and is there a way to identify if i have a 90-93 block or 94-95?
i was doing some searching but not too sure but i believe the green plug on the back of the motor came in the 92-93 ls and instead of the switch being on the thermostat its located on the back of the block?
i guess i just have to cut my hardness plug and extend the wires to the back of the block
can anyone confirm?
can anyone confirm?
my thermostat housing doesn't have any fan switch thats why im confused, could it be i have to just extend wires to the back and use that plug for the fan switch?
The fan switch IS on the back of the block on the LS and its NOT on the t stat housing. The fan switch is beside the green plug you have you extend the wirels for your fan switch if your using a 92-05 harness. As for the green plug i never used it so there for not caring what it was for.
tradesalot
16
Sep 19, 2004 09:07 PM
