300hp+ sohc's which injectors are you runing?
Old Sep 26, 2007 | 02:08 PM
RACEPAK's Avatar
Default 300hp+ sohc's which injectors are you runing?
poll
Old Sep 26, 2007 | 02:11 PM
urbansi's Avatar
Default Re: 300hp+ sohc's which injectors are you runing? (RACEPAK)
dont think a poll is necessary. I wouldnt suggest running anything smaller than a 450. Best bet is to run like a 750cc so if and when in the future you want to upgrade, theres no worries
Old Sep 26, 2007 | 03:33 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: 300hp+ sohc's which injectors are you runing? (urbansi)
he said it.....
550's is a good medium....
Old Sep 26, 2007 | 03:41 PM
dohcdelsol's Avatar
Default Re: 300hp+ sohc's which injectors are you runing? (S@nt0s)
550's or 720's
ima run 720's (same hp goal as you)
Old Sep 26, 2007 | 04:58 PM
turboteener's Avatar
Banned
Run the smallest ones you can safely get by with. 450s will do the job but be borderline. 550s should work perfectly. Might go to 600 and change if you can find them. They will idle easier than really big injectors.
Plus you can find 550s cheap as everyone wants to upgrade.
Old Sep 26, 2007 | 06:15 PM
fjt's Avatar
fjt
Nothing smaller than 550cc
At 266whp and with the AFR at 11.6 - 11.8 my 450cc where almost maxed out..More than 85% duty cycle
Old Sep 26, 2007 | 08:29 PM
JaredKaragen's Avatar
Default Re: (fjt)
at what altitude? (to see what side of the scale you are on)
Old May 10, 2008 | 11:26 PM
Rtboy10's Avatar
use 660's or 750's if you want to make more power later
Old May 11, 2008 | 10:37 AM
ptftw's Avatar
Default Re: (Rtboy10)
i think 550cc is good enough...
Old May 11, 2008 | 11:43 AM
RACEPAK's Avatar
Default Re: (ptftw)
got me some 780's but also raisd the power goal...
Old May 11, 2008 | 12:26 PM
Quad-Damage's Avatar
Default Re: (RACEPAK)
720's at 329 whp on pump
Old May 11, 2008 | 02:27 PM
Tippyman's Avatar
Default Re: (Quad-Damage)
I got precision 680's.
Old May 11, 2008 | 04:22 PM
Newt Dog's Avatar
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">I got precision 680's.</TD></TR></TABLE>
I run precision 1000cc injectors with no idle issues with AEM EMS
I always go larger than my power goal because it changes every week! lol
Turbocivic94
Oct 18, 2004 04:57 PM
DailyBlown
Aug 3, 2003 08:00 AM
pkripper94
Apr 7, 2003 07:19 PM
KevronsEG
Aug 13, 2002 07:34 PM
bambooluv
Apr 5, 2002 08:28 AM
