Spark plugs for high compression y8?
Old Sep 26, 2007 | 02:02 PM
CALC!_JUST_du_IT!'s Avatar
Default Spark plugs for high compression y8?
Hey guys, I'm wrapping up my build this weekend, and I'm not sure if I should get OEM spark plugs, or if something else might be better. It's a d16y8, with 11.0:1 cr. What do you guys recommend?
Old Sep 26, 2007 | 02:09 PM
sicones's Avatar
Default Re: Spark plugs for high compression y8? (CALC!_JUST_du_IT!)
BKR6E-11 is perfect
Old Sep 26, 2007 | 02:15 PM
Default Re: Spark plugs for high compression y8? (sicones)
It looks like those are made for 99-00 si's... Are you sure you didn't mean ZFR4F-11. That's the same plug, but for 92-00 ex's.
Thanks for the quick reply.
Old Sep 26, 2007 | 02:30 PM
sicones's Avatar
Why the hell would you want those, they're 1 step hotter, extended AND projected
the BKR6E-11 are 1 step cooler and non-extended
and btw those arent even for the EX civics, your stock plug is ZFR5F-11
janiscrulzz
12
Jan 10, 2012 12:14 AM
99hondacura
Sep 23, 2007 06:37 AM
downest
May 12, 2006 11:05 PM
