will 88-89 door panels work on a 90-91 civic? and 4 door rear handles...
Old Sep 26, 2007 | 01:10 PM
EF9 JAMS!!!'s Avatar
Default will 88-89 door panels work on a 90-91 civic? and 4 door rear handles...
as title states....i don't see why they wouldn't but i don't have any 88 door panels to try out.
how do ou guys do this. i love the idea of keyless. but can someone explain how this is done with a little bit of detail? would i have to buy the "actuator" for the locks or what?
Old Sep 26, 2007 | 05:42 PM
CRX1.4DualCarb's Avatar
Default Re: will 88-89 door panels work on a 90-91 civic? and 4 door rear handles... (EF9 JAMS!!!)
Yes that is the actuator, and unless you can get it for free (hurray!) you will have to buy it. They usually come in a kit, with two actuators a control box and a keyless transmitter.
Those are sedan rear handles. (or rover 214/216, or honda concerto or.. you get it). I have that same setup.
You could possibly use a honda doorlock (latch) with integrated actuator from a concerto, rover, civic eg, etc.. but I don't know for sure if it will fit. If so it would be inside the door latch and make the installation much cleaner.
If using the rear handles, also remove the rod that would connect to the handle keylock. I discovered that if let loose they would make those annoying noises...
Old Sep 26, 2007 | 05:46 PM
Default Re: will 88-89 door panels work on a 90-91 civic? and 4 door rear handles... (CRX1.4DualCarb)
thanks man. where can i buy this kit from???
Old Sep 28, 2007 | 04:03 PM
ebay. or any auto parts store I think. Or any house that sells car alarms.
good luck with it.
wallytucker
Honda Civic (2001 - 2005)
Aug 6, 2017 03:21 PM
bigedgar
11
Feb 28, 2016 01:04 PM
trfd13
Feb 18, 2013 02:50 PM
djrico724
Feb 9, 2009 06:31 AM
GSlowR
Jan 27, 2002 06:15 PM
