k20a2 trany
Old Sep 26, 2007 | 11:38 AM
psegs80's Avatar
Default k20a2 trany
I'm have a built b18c type r in my 2000 civic which I use for regional racing in Canada. I'm considering a k20a2 engine and transmission. I'm wondering if it comes with a LSD and if so, is it the same as the DC5 type r????
I will install a 5.062fd for sure but keep the oem gears.
Thanks
Old Sep 26, 2007 | 12:52 PM
FullEP3's Avatar
Default Re: k20a2 trany (psegs80)
K20A2 does not come with a LSD ... only the JDM K20A (Type R) motor comes with LSD ... there are other differences between the motors ...
Old Sep 26, 2007 | 02:50 PM
psegs80's Avatar
Default Re: k20a2 trany (FullEP3)
pistons, cams, intake manifold is there anything else???
Old Sep 26, 2007 | 05:20 PM
risktypeS's Avatar
this question has been answered 5 billion times.. read signature
Old Sep 26, 2007 | 05:27 PM
posHonda's Avatar
Does it really matter about the differences? Built k20a2 vs built JDM k20a thered practically be no difference.
Old Sep 26, 2007 | 07:45 PM
Master23's Avatar
If you have a built Type R then you should just stick with it. It's going to cost you more money if you switch to the K series.
K20A
217hp 158tq
4.7 final drive LSD
11.5 compression
Bigger Cams
PRC manifold
Old Sep 26, 2007 | 08:28 PM
psegs80's Avatar
Default Re: k20a2 trany (Master23)
I have a buyer at 8,500 for my complete setup and would have 10K for a k20a2. What makes me want to make the move is the midrange power difference and the wider powerband!!!
Pat
Old Sep 26, 2007 | 08:42 PM
1llmatic's Avatar
New User
K20 definitely has an advantage especially on the track over the B18.
But you will need to install an aftermarket LSD.
Old Sep 26, 2007 | 09:46 PM
Master23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psegs80 &raquo;</TD></TR><TR><TD CLASS="quote">I have a buyer at 8,500 for my complete setup and would have 10K for a k20a2. What makes me want to make the move is the midrange power difference and the wider powerband!!!
Pat</TD></TR></TABLE>
Seems like a good deal. Go for it.
Old Sep 27, 2007 | 05:58 AM
psegs80's Avatar
I'm debating buying a Kaaz 1.5way like I have in my b18c or simply buying a new k20a (jdm type r) trany from Honda....I can get them for 2500 new!
Who makes a good baffled oil pan for the K
Modified by psegs80 at 8:32 AM 9/27/2007
Old Sep 27, 2007 | 09:36 AM
1llmatic's Avatar
New User
Mugen and Toda both make baffled oil pans
Mugen:
http://www.kingmotorsports.com...at=72
Toda:
http://todaracing.com/category...id=62
Old Sep 27, 2007 | 10:31 AM
psegs80's Avatar
Default Re: k20a2 trany (1llmatic)
What about Moroso, that's what I have right now but couldn't find a part# for a K???
Old Sep 27, 2007 | 11:36 AM
FullEP3's Avatar
What are your plans for this car/engine? Just asking since I am curious why you are looking for baffled oil pans. I have a dedicated track car and have never run into an oil starvation issue using the stock oil pan. I could see a baffled oil pan being necessary on an oval track since oil will get pushed to one side for extended periods, but you won't really run into this issue with most road courses and you'll def not run into this on the street.
If you plan on building a true race car and that is its sole purpose... then sure I would invest in one, but I don't see it necessary on a street car (even with occassional auto-x/HPDE days).
Old Sep 27, 2007 | 11:54 AM
psegs80's Avatar
It's a race car for the CCTC (Castrol Canadian Touring Car Championship)
- Rbc manifold, hondata gasket and a 64mm inlet TB (largest permited)
- K20a2 engine with SK2 stage 1 cams, baffled oil pan, oil cooler, ATI single harmonic pulley. AEM EMS (get the ems for a good price)
-Type R trany or 5.062 OEM fd with type s trany with a kaaz dif.
- custom header (local guy) and cat back.
- As for radiator is still have to figure it out...I have a Fluidyne Type R in my EK now with samco hoses but they are sold with my setup + don't fit.
Old Sep 27, 2007 | 02:25 PM
1llmatic's Avatar
New User
it doesn't seem like moroso makes one for the K yet.
psegs...will upgrading to the k20 move you up a class though?
My friend had to bump up a class because of his k swap in his dc2 for the Solo1 Ontario solo sprints
Old Sep 27, 2007 | 04:11 PM
psegs80's Avatar
Does your friend drive a red dc2!!!
Old Sep 27, 2007 | 05:55 PM
1llmatic's Avatar
New User
yes he does have you seen him before?
here's a pic of his car:
Modified by 1llmatic at 10:25 PM 9/27/2007
Old Sep 28, 2007 | 04:47 AM
psegs80's Avatar
Yep, I met him at a track day at Shannonville a few weeks back!!!
Good driver and his k20a is putting down 238whp on a dynojet....fast
Old Sep 29, 2007 | 02:19 AM
1llmatic's Avatar
New User
nice nice...i taught him everything he knows...hahaha not really
he is a good driver. I was the one that pushed him to do the k-swap instead of building up his b18c. Turned out to be a great decision.
Old Oct 1, 2007 | 12:34 PM
psegs80's Avatar
Well, I took a few laps in the passenger seat and I noticed a big difference coming out of the corners powerwise for sure.
I know Dave and Pat from Defcon....I'm the rep for Bully Performance clutch!
Old Oct 16, 2007 | 07:38 AM
rockstar91's Avatar
yeahh just get the k20A motor...(jdm type r)
Old Oct 16, 2007 | 10:03 AM
t-town_ep's Avatar
that final drive will be bad a$$
dblair
May 3, 2013 01:21 PM
GT30RSX
Mar 1, 2007 03:29 AM
glagola1
14
Apr 29, 2003 08:39 AM
Name
May 13, 2002 02:00 PM
rpm9100
May 4, 2002 12:59 AM
