possible bad rings?
Old Sep 26, 2007 | 11:17 AM
turbo-crx's Avatar
Default possible bad rings?
well i have a turbo crx and the other day i did a 4th gear pull let by choice shifted to 5th and then i noticed my mototr had a different pitch to it. i pulled the plugs they were black so i put new ones in and it still did the same thing. it smokes from the intake manifold area but i cant tell where its coming from and when im driving and give it half throttle it smokes but i cant tell what kind of smoke it is. there is no smoke coming out of my down pipe. im doing a compression check to night and see if its the rings or not. what do you guys think?
Old Sep 26, 2007 | 12:47 PM
GreenBean's Avatar
Default Re: possible bad rings? (turbo-crx)
Forget the comp test, perform a leak down test and be sure it's not something else letting air in...
Let us know what the compression looks like...
pizzamanprelude
Sep 28, 2006 10:51 AM
silverboost
Nov 8, 2005 01:01 PM
Pfieff
Mar 8, 2004 07:19 PM
S2KP
Oct 24, 2003 03:39 AM
DxTrix
Aug 15, 2003 04:58 PM
