Engine Confusion
Old Sep 26, 2007 | 10:42 AM
sick93sol's Avatar
Default Engine Confusion
I have a 2000 Civic Si B16 block. I was wondering if any v-tec dual cam head will fit on it. Im in a class and i need to buy a head for it to get some experience working on heads and i want it to be a honda, so I need to know what heads are applicable for it, thanks.
Also is the 2000 Si B16a Identical to the 95 Del sol B16a? if not then what are the differences? Thanks guys, any info is useful.
Old Sep 26, 2007 | 10:55 AM
nicks-eg6's Avatar
Default Re: Engine Confusion (sick93sol)
yes any b-series head will work. but why wouldn't you just stay with the b16 head ? there easy to source and a great starting point for a build.
Old Sep 26, 2007 | 11:14 AM
sleeperrex's Avatar
Default Re: Engine Confusion (nicks-eg6)
itr, si , or gsr will work. b16, b18c's
Old Sep 26, 2007 | 11:56 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick93sol &raquo;</TD></TR><TR><TD CLASS="quote">I have a 2000 Civic Si B16 block. I was wondering if any v-tec dual cam head will fit on it. Im in a class and i need to buy a head for it to get some experience working on heads and i want it to be a honda, so I need to know what heads are applicable for it, thanks.
Also is the 2000 Si B16a Identical to the 95 Del sol B16a? if not then what are the differences? Thanks guys, any info is useful.</TD></TR></TABLE>
yes, all DOHC VTEC heads can bolt up to any b-series block. and yes the 2000 si B16A2 is identical to the 96-97 del sol B16A2.
but if are going to start teching yourself, (unless you have money like that) i don't recommend starting with this type motor or head. my reasoning behind it is the parts are some what expensive and harder to find than d-series motors.
start out building a d-series motor, get the confidence and experience you need and them go with a b-series head.
Old Sep 26, 2007 | 12:13 PM
crazyguy's Avatar
Default Re: Engine Confusion (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
start out building a d-series motor, get the confidence and experience you need and them go with a b-series head.</TD></TR></TABLE>
+1
philosofy knows his stuff..
Old Sep 26, 2007 | 12:15 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
I'm gonna go take the head off my S2000 and put it on my friend's B16A and vice versa. You better be right. I also plan on taking off my friend's K20Z head for the same purposes. I'll try the same thing with a prelude.
lol. sorry i had to.
OP: all DOHC VTEC heads that are from a B series will fit your B16A. Except maybe the B20 out of the 2nd or 3rd gen (i forget) preludes. Other B series heads (non VTEC) will bolt up, but there's the oil line problem.
The B16A head is the same head casting as the ITR/CTR. This is a very nice head. If you like nice head (who doesn't), then there's really no need to stray from this head. It bolts on to your B16A...keeps stock compression and combustion chamber volumes, and you can keep your stock manifold or get an ITR manifold.
The GSR head will bump up compression slightly provided all else stays the same. But you'll need an intake manifold for a GSR or a modified B16/B18C5 manifold to fit. It will also bolt on.
Old Sep 26, 2007 | 12:45 PM
philosofy1's Avatar
Default Re: Engine Confusion (B serious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B serious &raquo;</TD></TR><TR><TD CLASS="quote">
you got me . i wasn't really paying attention when typing. good catch though .
just stay away from swapping s2000/k20 heads on to b-series blocks.
Old Sep 26, 2007 | 01:58 PM
B serious's Avatar
just stay away from swapping s2000/k20 heads on to b-series blocks. </TD></TR></TABLE>
iduno. sounds like fun.
Old Sep 27, 2007 | 07:25 PM
sick93sol's Avatar
thanks guys that helps a lot. I wish I had the b16 head from that block, but i dont and everyone wants too much for a b16 head is why im asking, and i just need something similar, im not really looking for upgrades, just trying to go through the rebuild process. I have a full b16a2 in my del sol, so im just looking for a similar setup so i will be able to work on the good b16 in my del sol. But thanks for the info guys...
TehTaylor
Apr 17, 2012 03:51 PM
civtegra_hybrid
Jul 23, 2004 11:48 AM
mr.beeks
Apr 17, 2003 02:33 PM
