B18 non vtec head on a B16a block will it work????
I recently blow my d16y8 head gasket, and I put a new one on and milld the head 30xxx, and put it back on but soon after it blow another head gasket, so I think that I worped the block, so I have this extra b16 short block, laying around and I wanted to put it in my civtegra, but I wanted to know if the ls head would work on this block or do I have to buy a b16 head, pls. help me out thanks
Location: Your really lame if you dock my points, WA, 98033
Re: B18 non vtec head on a B16a block will it work???? (civtegra_hybrid)
im sure you could.. i think it would be the exact opposite of the ls/vtec so you would need to tap the holes. and relocated the dowel holes. use the b16 head bolts and gasket. and b16 timmingbelt. thats all i can think of off the top of my head.
Re: B18 non vtec head on a B16a block will it work???? (Jumpmann23)
just to correct something
you cant use b16 head bolt with a b18a head,you need b18a head bolts
also for the person wanting to do this,dont bother,your better off picking up a vtec head
Re: B18 non vtec head on a B16a block will it work???? (jdm civic 2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm civic 2000 »</TD></TR><TR><TD CLASS="quote">
also for the person wanting to do this,dont bother,your better off picking up a vtec head </TD></TR></TABLE>
i totally agree. Torqueless and powerless. Ls head on a b16 block might be a crappier motor than the d series vtec motor . Same yourself frustration and get the vtec head.
the swap is for my wife, and right now it has a D16y8 in it sohc and I think that any B ser. swap, non vtec or vtec will be better the what she's got lol. and any ways have you seen how much B16 heads are going for now, there like $650. I can buy a whole B16a long block for that much. lol
your better off repairing the head gasket on your sohc...because that idea will not do anything,it will produce around 125 hp maybe less.a nonvtec b18a/b makes 140 hp and the torque from the long stroked crank,a b16 stroke is tiny tiny making next to nothing with the the crappy b18a head....the idea is hopeless....also if you really look around,you will come across a crack head deal.....,or sell or trade the b16 bottom for a b18a/b bottom....that the best option,i caould say
yeah all that may be true, but the block for the sohc is warped, and I would have to pull it out and remove the pistions and send the sohc block to get reserfaced, that alone will bee like 300, Im just puting the B18 head on the b16 block for right now, I plan to get a B16 head later, but as for now that's all I got, so that's why I wanted to know if it would work. I don't really care about if it's more power then my old D16y8, I just want that bitch to run lol. so I hope it will work cuz that's all I got to swap in it right now.
i agree with drunknbass.
I thought about this swap before, seeing as how you can find the leftovers of someone's LS VTEC swap for pretty cheap. hog out the LS head and get some fatty cams and rev it to 9,000 all day long :D
or, you could turbo it, and have a 1.6L DOHC but with stronger internals and the ability to rev to 9k with proper valvetrain.
I'm not saying that it should be your preferred engine, but im sure it has possibility
