90 ef... i need to remove my resistor box
wassup H-T! i've got a 90 ef and my injector blew out. it's a b18a1 block with b16a2 head... and i'm using aftermarket injectors with a resistor box. I've got some obd1 injectors that should work but i need to remove my resistor box. any how to's? i read mostly that u need to connect all the wires but a diagram or picture might be better.I'm excellent at wiring, it's what i did on a daily basis for a year and a half as an installer so it shouldn't be a problem... i just need to kno what goes where so if it doesn't work i can trouble shoot it. thx a lot H-T
Here you go, its very simple. Scroll down a bit.
http://www.rywire.com/store/im...r.gif
I know I'm digging up an old thread, but this is awesome!!! I have been searching around for about a half hour trying to find out a clean, correct way to delete or remove my injector resistor box in my 91 CRX. I'm running obd1 injectors so I need to remove my box and this was the first thread to answer ALL of my questions. The link to rywire was great!
I think this needs to be added to the FAQ...
and after you connect the 4red and the 1 yellow wires, the injector clip sould now be geting 12v correct. sorry for diging up old thread. but every1 complains about not searching
90hatchblack
Feb 26, 2007 05:19 AM
HatchBox
12
Jan 13, 2006 05:29 PM
