4- crank Position sensor 10 IAT 15 ignition output signal m
Old Sep 26, 2007 | 06:02 AM
dougshatch's Avatar
Default 4- crank Position sensor 10 IAT 15 ignition output signal m
im having problem how can i solved those id apprection for fast replied
Old Sep 30, 2007 | 05:29 AM
lilpastrana's Avatar
Default Re: 4- crank Position sensor 10 IAT 15 ignition output signal m (dougshatch)
thank you. i have THE exact same codes. i am in limp mode also. did you do a swap or somthing ?
i did a gsr swap into 91 crx and did obd to obd 1 and dp to mpfi. HELP !!!!!!
Wilfre114
Feb 9, 2023 08:07 AM
4drboostking
May 19, 2015 02:37 AM
ahc'monracing
Sep 23, 2002 03:36 PM
prjctCIVIC
Aug 26, 2002 08:34 PM
