Noise from type-S rear hatch/suspension/swaybar?
Old Sep 25, 2007 | 08:19 PM
Quik89Si's Avatar
Default Noise from type-S rear hatch/suspension/swaybar?
Anybody else get a squeaking noise from the rear hatch/suspension when driving over uneven pavement, like crossing on to the slope of a driveway at an angle? It doesn't squeak when I go over a speedbump straight on, though. Not sure what I need to grease or check out to fix this. Suggestions are appreciated!
Alex
Old Sep 25, 2007 | 10:03 PM
NTCustoms's Avatar
tighten everything, and lube
Old Sep 26, 2007 | 08:46 AM
WhiteOnRice's Avatar
Try greasing a bunch of bushings (especially LCA's and swaybar).
Old Sep 26, 2007 | 09:58 AM
Quik89Si's Avatar
Default Re: (WhiteOnRice)
That's what I was thinking of doing. Hopefully greasing the swaybar bushings fixes it, the other ones are a bigger PITA to get to. What type of grease will work best for bushings? What does Honda use?
Old Sep 26, 2007 | 02:25 PM
NTCustoms's Avatar
use white lithium grease
Old Sep 27, 2007 | 05:25 PM
Take the brackets off and use polyurethane grease. White lithium is easier but not viscous enough to last.
Old Sep 27, 2007 | 06:18 PM
Quik89Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">Take the brackets off and use polyurethane grease. White lithium is easier but not viscous enough to last.</TD></TR></TABLE>
Good to know. Thanks!
jorge59la
Dec 1, 2010 12:01 AM
phikshin
Suspension & Brakes
Jun 11, 2009 12:03 AM
Jstans84
Honda Civic (2001 - 2005)
May 5, 2008 07:56 AM
katsareus
Jun 19, 2006 04:42 AM
blkgsr03
Jun 10, 2003 09:52 PM
