FS: 1997 Integra GSR-T in Kansas
12K
Clean title, 92K Miles on Body 1K on motor. Tuned for 91 Octane 400whp 303Tq
AEBS Sleeves with copper rings
AEBS Head Studs
ACL Bearings
Pauter Rods
Ross Pistons
Supertech Valves, Retainers, Springs
ARP Main Studs
Cometic Head Gasket
Quaife LSD
AEM Fuel Filter
AEM Fuel Rail
Aeromotive Fuel Pressure Regulator
Driveshaft Shop Axles
Skunk2 Intake Manifold
Skunk2 Throttle Body
Type-R Throttle Body Cable & Bracket
Precision 1000CC Injectors
Precision Front Mount Intercooler
Hondata S300
Hondata Manifold Gasket
GM Boost Selenoid
GM 3 Bar MAF
KMS Maf Block Off
MSD Wires
MSD Cap & Rotor
MSD 6A
MSD Coil
Greddy Catchcan
Golden Eagle MFG Vaccum Manifold
Tial Wastegate
Turbo XS RFL
SKunk2 Short Shifter
Skunk2 Shift ****
Koyo Radiator
Hayden Slim Fans
Greddy Raditor Cap
Stainless Steel Modify'd Ram Style Turbo Manifold
Stainless Steel Modify'd 2.5" Intercooler Piping
Hose Techniques Turbo Gaskets
Stainless Steel Modify'd 3" Downpipe With V-Band
Stainless Steel Modify'd Dumptube
Stainless Steel Vibrant 3" Turboback Exhaust
Stainless Steel Vibrant 3" Resonator
PLX Wideband M300
K&N Air Filter
K&N Crankcase Filter
Turbonetics T3/T4 (66) Turbo
Earl Turbo Oil Fittings
Fluidampr Crank Pulley
Moroso Oil Pan
Moroso Oil Pan Studs
Skunk2 Springs
Skunk2 Front & Rear Strut Tower Bar
Omni Power Front & Rear Camber Kit
Omni Power Lower Control Arm
Suspension Techniques Front & Rear Sway Bars
ASR Subframe Support
Full-Race Traction Control Bar
HASport Motor Mounts
Brembo Rotors
Wahlbro Fuel Pump
AXXIS Brake Pads
Russell Stainless Brake Lines
Energy Suspension Lower Mount Inserts
Competition Stage 4 Ironman Clutch & Ultralight Flywheel
Viper Alarm With Turbo Time
Tokico Blue Shocks
Shaved Door Molding
Shaved Rear Trunk Lights
Shaved Integra Emblems
Eclipse MP3/CD Player
Prosport Electronic Boost & Oil Gauges
Wings West Body Kit
Golden Eagle Towhook
VIS Racing Hood
Aerocatch Hood Pins
Only Honda Oil Filters & Honda Oil Used
Custom A/C Line
Oil Pump, Timing Belt Have 1000 Miles On It
Modified by WickedMotorsports at 6:07 AM 9/27/2007
AEBS Head Studs
ACL Bearings
Pauter Rods
Ross Pistons
ARP Main Studs
Cometic Head Gasket
Quaife LSD
AEM Fuel Filter
AEM Fuel Rail
Hondata S300
GM Boost Selenoid
GM 3 Bar MAF
KMS Maf Block Off
MSD Wires
MSD Cap & Rotor
MSD 6A
MSD Coil
Greddy Catchcan
Tial Wastegate
Turbo XS RFL
Skunk2 Shift ****
Koyo Radiator
Hayden Slim Fans
Greddy Raditor Cap
PLX Wideband M300
K&N Air Filter
Moroso Oil Pan
Skunk2 Springs
Brembo Rotors
Wahlbro Fuel Pump
AXXIS Brake Pads
Tokico Blue Shocks
Shaved Door Molding
Wings West Body Kit
VIS Racing Hood
Aerocatch Hood Pins
Custom A/C Line
