Differnence in between em1 and ej8 exhaust?
Old Sep 25, 2007 | 05:00 PM
turnsignalandy's Avatar
Default Differnence in between em1 and ej8 exhaust?
Whats the difference in between a civic ex and si exhaust? The reason for asking is that I have a ex with the Si rear swaybar, and am wondering if the si exhaust is bent differently to clear it? Im about to buy a aftermarket exhaust
Old Sep 25, 2007 | 05:57 PM
b 1 6 a 2's Avatar
Default Re: Differnence in between em1 and ej8 exhaust? (turnsignalandy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">Whats the difference in between a civic ex and si exhaust? The reason for asking is that I have a ex with the Si rear swaybar, and am wondering if the si exhaust is bent differently to clear it? Im about to buy a aftermarket exhaust</TD></TR></TABLE>
Both exhuasts fit; the ex muffler will clear the SI sway bar. The only difference is that the si exhuast piping is a bit larger (probably up to .25 inches) but it tapers to a restrictive section (forgot where), which is definately the most retrictive part of the system.
Overall the SI exhuast system is a bit larger in diameter than the EX. I had the complete EX ehuast with the SI sway bar for a few years, then i paid $20 to get the complete SI exhuast; I am also using the CAT off the EX with SI piping.
The SI bends are very similar to the EX. Problem is, an aftermarket exhuast may vibrate against the sway, depending on the manufacture. I had a bolt axleback that rested on the sway bar and would clunk every-so-often.
Old Sep 25, 2007 | 06:00 PM
RiceKillinSI's Avatar
There is no difference between the two. you should be fine. If you are still worried just cross reference the part numbers for the specific exhaust you are buying.
Old Sep 25, 2007 | 06:18 PM
Default Re: Differnence in between em1 and ej8 exhaust? (RiceKillinSI)
so if i get one for an 99-00 Si it will bolt up to a 97 ex no problem?
Old Sep 25, 2007 | 08:27 PM
Yes, if you look most companies will list a exhaust for an EX and another one for the Si, but if you look at the part numbers they will be the same.
Old Sep 25, 2007 | 08:31 PM
well here is the one for 92-98 honda 2/4door
http://www.invidia-usa.com/Pro...ID=37
part number HS92HC2G2P
and one for 99-00 type R 2/4 door
http://www.invidia-usa.com/Pro...ID=38
part number HS99HC2G2P
IDK which one to get
Old Sep 25, 2007 | 10:30 PM
It looks like one is for 92-98 and the other is for 99-00 civics. If you have major worries just click the support link on the web site and send them an e-mail. i'm sure they can help. Also do some research on google, you can find that exhaust for a lot cheaper that $699.
http://www.mufflerguy.com/p-21....aspx
Old Sep 26, 2007 | 12:08 AM
pkdog167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turnsignalandy &raquo;</TD></TR><TR><TD CLASS="quote">well here is the one for 92-98 honda 2/4door
IDK which one to get</TD></TR></TABLE>
THe part # are the same.
Old Sep 26, 2007 | 01:24 AM
Default Re: Differnence in between em1 and ej8 exhaust? (pkdog167)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pkdog167 &raquo;</TD></TR><TR><TD CLASS="quote">
THe part # are the same.</TD></TR></TABLE>
Not quite.
Old Sep 26, 2007 | 07:41 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceKillinSI &raquo;</TD></TR><TR><TD CLASS="quote">It looks like one is for 92-98 and the other is for 99-00 civics. If you have major worries just click the support link on the web site and send them an e-mail. i'm sure they can help. Also do some research on google, you can find that exhaust for a lot cheaper that $699.
http://www.mufflerguy.com/p-21....aspx</TD></TR></TABLE>
im gettin it for $450 shipped
Colin00
Honda Civic (2006 - 2015)
Apr 23, 2011 09:57 PM
Jblack18
Jun 6, 2009 11:40 AM
dingle
Dec 6, 2005 05:55 PM
tinkfist
Dec 2, 2002 02:11 PM
