new pistons question..answer fast pl0x
Old Sep 25, 2007 | 04:58 PM
chadalac1712's Avatar
Default new pistons question..answer fast pl0x
Im thinking about buying SRP Piston set for D16Z6 10.5:1 +.010 Bore.... im gonna get the rings for the extra 77$...should i get eagle rods to go with it? and will i need to buy a new head gasket if i get these put in and if i am missing anything else i need lemme know
10:5:1 pistons .10 bore
piston rings
eagle rods
anything else?
Old Sep 25, 2007 | 05:23 PM
drtysohc's Avatar
thats what I had in my y7, and it held enough power to last longer than the sleeves
Whatever you do, DON'T, I repeat, DON'T get a block guard....that is what caused the failure of my 400whp single cam.
The only other thing that I could think of that you will need to build your shortblock would be a new set of OEM rod bearings, head gasket and a set of ARP head studs
Old Sep 25, 2007 | 05:52 PM
ya i already got a head gasket i went ahead and bought 1 bc i was gonna do something and i got it for 75$ from honda....and i thought about the head studs but ill deff get them now... what will the rod bearings do
Old Sep 25, 2007 | 05:54 PM
drtysohc's Avatar
If you're going to put new rods in the motor, you need to replace the bearings as well. ARP head studs are a MUST on single cams, as they like to lift the head. Single cams have head gasket issues out the ***, so do anything you can do to prevent future issues.
Old Sep 25, 2007 | 06:05 PM
i cant find out if cp has 10:5:1 pistons.. if not im gonna have to run with the srp...the golden eagle rods at the shop near me come with arp rod bolts.. ill buy new rod bearings sometime after i get all this ****...i wont put it in for another month.. have to write papers and **** and document it..for school project to pass senior year
Old Sep 25, 2007 | 06:17 PM
drtysohc's Avatar
The SRP/Eagle combo is more than enough for a single cam
Old Sep 25, 2007 | 06:21 PM
cant wait to see the #'s off this..i know it aint much but i want at least 130whp...if i dont get that off pistons ill cry
Old Sep 25, 2007 | 07:15 PM
maynards_ek's Avatar
Default Re: (drtysohc)
Wait a sec drtysohc, you dont think running 27psi on stock sleeves was the cause of failure? Just messin with ya. Hey, thanks for the 2.5 map, I needed one bad. And if you still have that wideband, I sure could use it. Hit me up on kcsr.
Old Sep 25, 2007 | 07:35 PM
Kyoh's Avatar
Default Re: (maynards_ek)
Don't forget your ARP rods bolts either. Very important.
Old Sep 25, 2007 | 07:44 PM
Solster's Avatar
Default Re: (Kyoh)
if you wan't a better piston set just get the ones from a D16A1 fron a 88-89 integra there a better CR in a D16Z6 thay make over 12.0:1 CR.
Old Sep 25, 2007 | 07:47 PM
projekt-sol's Avatar
Default Re: (Solster)
i hate to ask this.. but if i did the same on a d15 would it be worth the $?
Old Sep 25, 2007 | 07:49 PM
the rods come with the apr bolts
mitchell_2kSiR
Jul 28, 2008 02:18 PM
NegativeXero
Jan 6, 2008 03:48 PM
ccivic
Mar 16, 2006 06:31 PM
huntarrr
Nov 2, 2005 05:38 PM
JM Performance
Nov 19, 2001 12:47 PM
