Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Civic vibration
Old Sep 25, 2007 | 04:25 PM
ryor01's Avatar
Default Civic vibration
Hi,
I have a Honda Civic 05 with 35,000 miles. Just recently, I noticed that the front end of the car starts to vibrate at 38mph. It only vibrates when I have the gas pedal depressed slightly. As soon as I let the gas go, or press on the pedal more, the vibration goes away. The vibration only starts at that speed/pedal depression combination. If I push on the pedal harder, the car accelerates quickly right past 38mph without vibrating at all. Any ideas what could be the cause of this? Thanks!
Old Sep 25, 2007 | 05:39 PM
i-VTEC_DOHC's Avatar
my old ej did that too but the prob was a bad front motor mount.. the rubber was prety much gone and it vibrated the whole fuggin car lol i highly doubt its a motor mount in your case
Old Sep 25, 2007 | 08:07 PM
Slidin'Sidewayz's Avatar
Sounds like its something to do with ur engine and its timing or fuel. Does it spark knock or anything like that? I know when your timing is too high on a chevy it will spark knock at certain speeds and usually around slower speeds about 30-40mph mostly when going up a hill or something that is straining the engine. Thats what it sounds like your problem is but not sure how to correct it on these things.
Old Sep 26, 2007 | 12:10 AM
toyomatt84's Avatar
Sanji
Default Re: (Slidin'Sidewayz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slidin’Sidewayz &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like its something to do with ur engine and its timing or fuel. Does it spark knock or anything like that? I know when your timing is too high on a chevy it will spark knock at certain speeds and usually around slower speeds about 30-40mph mostly when going up a hill or something that is straining the engine. Thats what it sounds like your problem is but not sure how to correct it on these things.</TD></TR></TABLE>
It's more likely to be a mounting or balance issue. I would recommend rotating the tires, and seeing if that doesn't change things.
Old Sep 26, 2007 | 02:31 AM
thinknology's Avatar
Default Re: (toyomatt84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">
It's more likely to be a mounting or balance issue. I would recommend rotating the tires, and seeing if that doesn't change things.</TD></TR></TABLE>
Sounds about right... since I lowered my car and put different tires on the back rims (they were ruined if ya'll remember) I don't get near as much vibration aaaannnndd my ABS and E-BRAKE light doesn't come on when I go over 65 anymore.
Telecatster
Aug 1, 2012 06:47 AM
Paul-R
Jan 12, 2009 04:17 PM
deh4567
Jul 29, 2008 01:35 PM
93coupeDX
Jan 7, 2004 08:09 AM
_Endless_
Feb 21, 2003 01:49 AM
